4200 HST with shift fork problems
/ 4200 HST with shift fork problems #1
hth
Bigfork, MT
John Deere 4200
I have a 4200 HST and it only works in C range. When I select A or B range it remains in neutral and goes nowhere. How hard is it to replace the shift forks and is there anything else I can try to get me running again in A range? When I talked to the dealership they said they would need to split the tractor and it would be at least 15 hours of work - not something I want to pay them for if I can do it myself or there is an easier fix. All the linkage on the outside is good and it shifts easily. I am fairly good as a mechanic i.e. I have replaced a timing belt and turbo and various other car parts but I have not worked on any transmissions.
Thanks for your help!
/ 4200 HST with shift fork problems #2
Get a workshop manual if you are going to do any work on your machine. Splitting a tractor is a lot more than a timing belt. You have a couple thousand lbs parts to properly support while you pull them apart.
Most things clutch related & a lot of transmission stuff requires splitting on most tractors.
/ 4200 HST with shift fork problems #3
Look up some threads on here about splitting tractors. Usually complicated and requires a fair amount of dedicated space.
/ 4200 HST with shift fork problems #4
You may be in luck. Sort of.
The range shifter rods commonly break, and I suspect yours has broken while you are in
the high range. It CAN be replaced without splitting the tractor, but you will have to
remove the 3-pt cylinder housing on top. I have it documented somewhere on TBN.
/ 4200 HST with shift fork problems #5
I have a PDF of the Deere technical manual that you're welcome to.
If wanted shoot me your email
Joe
/ 4200 HST with shift fork problems #6
Did you ever find what was causing no A or B range? What was the fix?
John Deere 4955 Tractor (A66285)
John Deere 4955...
20 Yard Roll Off Dumpster (A65579)
20 Yard Roll Off...
2008 DRAGON  130BBL VACUUM TRAILER (A65643)
2008 DRAGON...
Skid Steer Mount 3pt Adapter  (A62679)
Skid Steer Mount...
SANY SY225C LC EXCAVATOR (A63276)
SANY SY225C LC...
Stout Utility Grapple XHD76 (A66285)
Stout Utility...
