4200 4wd indicator switch
/ 4200 4wd indicator switch #1
Mighty Dodge
Platinum Member
The Hereford Zone, MD
JD 4200
My 4wd light doesn't come on. Does anyone know where the switch is that activates the 4wd light? I've determined the bulb is good. It does go into 4wd but I get no light on the dash. I've looked on JD parts, don't see it.
Thanx
M.D.
/ 4200 4wd indicator switch #2
Are you sure you had a bulb that lit up on your 4200? I know for a fact I never had one on my 4200. Because I saw an icon for 4WD on my dash, but remember looking underneath and there was not socket at all for a bulb. I had one of the first models of 4200's when they came out though. Because when I got my 3720, I was happy that I finally had an indicator light.
Yup got a socket with a bulb in it. It did work then stopped. I switched the bulb to another socket and it lights fine.
M.D.
/ 4200 4wd indicator switch #4
Are you sure it's actually switching to 4WD mode? Hopefully it's just bad circuitry in the indicator but the mechanism works fine.
/ 4200 4wd indicator switch #6
The 4200 has a light for 4WD? Hmm. My 4600 doesn't have one... I just note the difference in the turning/pull/etc. and the fact that the lever is still pulled up.
Is this light on all 4x00 models? :confused:
-Bob
/ 4200 4wd indicator switch #9
dbdartman said:
My 4400 doesn't have a 4WD light on the dash, or if it does, it doesn't work. I just look down at the lever. :D :rolleyes:
Likewise on my John Deere 4500. I asked the dealer about it when it was under warranty- factory never made it a "working" light.
/ 4200 4wd indicator switch #10
Ah. Good. After 5 years I'd hate to think that I would have missed that light not being on... :eek:
-Bob
250 GALLON FUEL TANK (A64280)
250 GALLON FUEL...
(2) UNUSED 25X10.00-12 TIRES W/ 4 LUG RIMS (A64280)
(2) UNUSED...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
(4) 205/75R15 TIRES W/ 4 LUG WHEELS (A64281)
(4) 205/75R15...
2023 Globe Trailer GTDD30236 36ft. 75yd. T/A End Dump Trailer (A61573)
2023 Globe Trailer...
2014 GMC SIERRA 1500 (A62613)
2014 GMC SIERRA...
