4200 3rd SCV QD Sizes?
/ 4200 3rd SCV QD Sizes? #1
arrabil
Winterstown, PA
JD 4200 & X475
Anyone know what size the QDs on a 4200's 3rd SCV are?
And is there a pictorial guide somewhere on the internet of all the different kinds?
Thanks!
/ 4200 3rd SCV QD Sizes? #3
Pretty sure they are 3/8" Pioneer's (Parker) 4000 Series Poppet style QD's.
I didn't realize the lettering was on the QDs.... 60 Series. Doesn't give a size though.
The 3/8" male end I had in the parts pins didn't fit. That one said 3/8" but didn't say what kind it is. Though it looks like the pictures for 60 series. Is it possible the QDs are 1/4" 60 Series?
Do you use teflon tape or pipe dope when screwing the connecters to the hose?
/ 4200 3rd SCV QD Sizes? #6
Never use teflon tape on your hydraulic system, little bits of it can get into the system and make a mess. Use a PTFE pipe dope rated for hydraulic use.
I use Loctite #565 or Permatex #80632
Parker 60 series
/ 4200 3rd SCV QD Sizes? #7
is the nipple serviceable? a couple of mine seep when i disconnect the loader, and i presume there is some sort of o-rings in there that must not be allowing it to seal properly.
Thanks Kenny!
defed, they all leak a little when you disconnect them. I think thats what the "new" flush mount ones are all about... eliminating the spillage.
/ 4200 3rd SCV QD Sizes? #9
right, there will be some leakage when you 1st disconnect, but 2 of my 4 will drip the whole time it's disconnected.
Ah. My 3rd SCV did that when I bought the tractor. I just replaced them. Actually, maybe thats why I have 60 series instead of 4000 series.... Gonna have to look at the spare parts bin again.
So which is better for a tractor living outside: brass or steel?
/ 4200 3rd SCV QD Sizes? #11
did you ever get your QDs? i got to looking at mine the other day, they are labeled: H3-63-T8 ...which is parker 60, 3/8" body and some funky 3/4 - 16 threads (ORB).
i can find lots of info on them, but don't see many places selling parker fittings...H3-63 seems easier to find, but not the T8 version. same w/ safeway. H3-63 = S101-3, while H3-63-T8 = S101-3-8....can find the non-ORB version easily, not so much for the ORB.
I've had the QDs on there from almost the beginning. They came with a bunch of parts I got for cheap on eBay. Must be the funky threads that threw me cause I have nothing I can screw into the ones I replaced.
Colombo Twin Master (A64126)
Colombo Twin...
Preliminary Listing / Full Catalog Coming Soon! (A62180)
Preliminary...
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A59904)
2017 FREIGHTLINER...
New/Unused Outdoor Propane Patio Heater (A65583)
New/Unused Outdoor...
New/Unused Quick Attach Auger (A65583)
New/Unused Quick...
2012 UTILITY VS2RA 53X102 T/A REFRIGERATED TRAILER (A59914)
2012 UTILITY VS2RA...
