4115 vs 4210
/ 4115 vs 4210 #1
loud
hi all--am in the process of buying either a 4115 or 4210--i have 15 acres i mow with a older 72" mower deck-i have an excisting 755 with a loader and backhoe and want a tractor with a little more power just for mowing --there is only $1000.00 diff in price so price is not an issue but i don't want anything to big to mow -my neighbor has a 4310 and it is quite big --another thing my son broght up can i put a backhoe on a 4115 if i ever want to do it--just for flexiblity--also want hydro trans
i mow a lot and want something that has cruise control and is comfortable
any thoughts pls
/ 4115 vs 4210 #2
Both can take a backhoe. You can get a synch-shift or hydro in the 4210, and the 4115 is hydro only.
Are you thinking of a belly mower or rear finish mower? The mid-pto is standard on the 4115 and an option on the 4210 if that matters. Both can handle a 72" MMM or RFM. Obviously more HP in the 4210...smaller frame and more agile in the 4115. IMHO, the 4115 is a great finish mowing machine becasue of the shorter wheel base.
/ 4115 vs 4210 #3
I think the 4210 is underpowered for it's size and the 4115 is a better balanced machine overall and IMHO the 4115 would be a better mower. It's also a Yanmar machine whereas the 4210 is not. You could also buy a used 3910 or 3930 for a whole lots less money and it would outmow either the 4115 or 4210.
/ 4115 vs 4210 #4
<font color="green"> It's also a Yanmar machine whereas the 4210 is not. </font>
huh? /forums/images/graemlins/confused.gif
MODEL 4210 4WD Compact Tractor (28 hp)
Engine
Manufacturer Yanmar 3TNE82A
Aspiration Natural
Cylinders/Displacement, cu. in. (liters) 3 / 81.16 (1.33)
Hydraulics
Type Open Center Standard 11.9 (45)
Rated Flow @ One SCV Steering 5.3 (20)
Max Output @ SCV Couplers GPM (L/M) Implement 7 (26.5)
Maximum Operating Pressure (PSI) 2125 (14352 kpa)
Hitch Category (SAE Designation) Category 1 Standard 1700 (771)
Actually there is a running change on the 4210 to a larger hydro pump which will give significantly improved numbers.
MODEL 4115 4WD Compact Tractor (24 hp)
Engine
Manufacturer Yanmar 3TNE78A
Aspiration Natural
Cylinders/Displacement, cu. in. (liters) 3 / 73.22 (1.2)
Hydraulics
Type Open Center Standard 7.4 (28)
Rated Flow @ One SCV Steering 2.3 (8.7)
Max Output @ SCV Couplers GPM (L/M) Implement 5.1 (19.3)
Maximum Operating Pressure (PSI) 2418 (16671 kpa)
Hitch Category (SAE Designation) Category 1 Standard 1150 (522)
Both are Direct injection fuel system
4115 is made in Japan, the 4210 is made in USA
/ 4115 vs 4210 #5
this has been discussed a lot, but the 4010-4115 are made 100 % percent
by Yanmar and then assembled in the U.S. The 4210 is made and assembled
in the U.S. minus the engine, which is obviously a Yanmar. Obviously,
JD buys parts from the sources all over the world, but for the sake
of simplicity, the above is true to the best of my knowledge.
/ 4115 vs 4210 #6
That's my point. The 4115 will have better build and component quality. It's 100% Yanmar.
/ 4115 vs 4210
thanks all for the info --i will be using a rear 72" mower and i mow about 15 acres-i do it now with a 755 JD but need more power --great point about the added weight of the 4210 with only 2 HP more
/ 4115 vs 4210 #8
</font><font color="blue" class="small">( That's my point. The 4115 will have better build and component quality. It's 100% Yanmar. )</font>
Oh, I get it, another April Fools Funny!!
/ 4115 vs 4210 #9
LOL. Might be true! Never had a probelm with Yanmar until ye ole 990 started to leak a little. I really got to drive it into work someday.
2023 WEILER K560 KNUCKLEBOOM LOADER (A65056)
2023 WEILER K560...
2008 Kohler 300REOZDD 375kVA Standby Diesel Generator (A66734)
2008 Kohler...
STORGE SPACE WITH MISC ITEMS (A68842)
STORGE SPACE WITH...
2023 JOHN DEERE 35P EXCAVATOR (A65056)
2023 JOHN DEERE...
2015 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A61573)
2015 Chevrolet...
2025 Pallet of Miscellaneous Duplex Polyester Webbing Slings (A66734)
2025 Pallet of...
