4115 vs 4210
/ 4115 vs 4210 #1
loud
hi all--am in the process of buying either a 4115 or 4210--i have 15 acres i mow with a older 72" mower deck-i have an excisting 755 with a loader and backhoe and want a tractor with a little more power just for mowing --there is only $1000.00 diff in price so price is not an issue but i don't want anything to big to mow -my neighbor has a 4310 and it is quite big --another thing my son broght up can i put a backhoe on a 4115 if i ever want to do it--just for flexiblity--also want hydro trans
i mow a lot and want something that has cruise control and is comfortable
any thoughts pls
/ 4115 vs 4210 #2
Both can take a backhoe. You can get a synch-shift or hydro in the 4210, and the 4115 is hydro only.
Are you thinking of a belly mower or rear finish mower? The mid-pto is standard on the 4115 and an option on the 4210 if that matters. Both can handle a 72" MMM or RFM. Obviously more HP in the 4210...smaller frame and more agile in the 4115. IMHO, the 4115 is a great finish mowing machine becasue of the shorter wheel base.
/ 4115 vs 4210 #3
I think the 4210 is underpowered for it's size and the 4115 is a better balanced machine overall and IMHO the 4115 would be a better mower. It's also a Yanmar machine whereas the 4210 is not. You could also buy a used 3910 or 3930 for a whole lots less money and it would outmow either the 4115 or 4210.
/ 4115 vs 4210 #4
<font color="green"> It's also a Yanmar machine whereas the 4210 is not. </font>
huh? /forums/images/graemlins/confused.gif
MODEL 4210 4WD Compact Tractor (28 hp)
Engine
Manufacturer Yanmar 3TNE82A
Aspiration Natural
Cylinders/Displacement, cu. in. (liters) 3 / 81.16 (1.33)
Hydraulics
Type Open Center Standard 11.9 (45)
Rated Flow @ One SCV Steering 5.3 (20)
Max Output @ SCV Couplers GPM (L/M) Implement 7 (26.5)
Maximum Operating Pressure (PSI) 2125 (14352 kpa)
Hitch Category (SAE Designation) Category 1 Standard 1700 (771)
Actually there is a running change on the 4210 to a larger hydro pump which will give significantly improved numbers.
MODEL 4115 4WD Compact Tractor (24 hp)
Engine
Manufacturer Yanmar 3TNE78A
Aspiration Natural
Cylinders/Displacement, cu. in. (liters) 3 / 73.22 (1.2)
Hydraulics
Type Open Center Standard 7.4 (28)
Rated Flow @ One SCV Steering 2.3 (8.7)
Max Output @ SCV Couplers GPM (L/M) Implement 5.1 (19.3)
Maximum Operating Pressure (PSI) 2418 (16671 kpa)
Hitch Category (SAE Designation) Category 1 Standard 1150 (522)
Both are Direct injection fuel system
4115 is made in Japan, the 4210 is made in USA
/ 4115 vs 4210 #5
this has been discussed a lot, but the 4010-4115 are made 100 % percent
by Yanmar and then assembled in the U.S. The 4210 is made and assembled
in the U.S. minus the engine, which is obviously a Yanmar. Obviously,
JD buys parts from the sources all over the world, but for the sake
of simplicity, the above is true to the best of my knowledge.
/ 4115 vs 4210 #6
That's my point. The 4115 will have better build and component quality. It's 100% Yanmar.
/ 4115 vs 4210
thanks all for the info --i will be using a rear 72" mower and i mow about 15 acres-i do it now with a 755 JD but need more power --great point about the added weight of the 4210 with only 2 HP more
/ 4115 vs 4210 #8
</font><font color="blue" class="small">( That's my point. The 4115 will have better build and component quality. It's 100% Yanmar. )</font>
Oh, I get it, another April Fools Funny!!
/ 4115 vs 4210 #9
LOL. Might be true! Never had a probelm with Yanmar until ye ole 990 started to leak a little. I really got to drive it into work someday.
CATERPILLAR D1 CRAWLER DOZER (A65053)
CATERPILLAR D1...
2018 FREIGHTLINER CASCADIA 125 6X4 T/S SLEEPER TRUCK TRACTOR (A69167)
2018 FREIGHTLINER...
Boat Motor. (A66738)
2015 Ford F-450 Knapheide Service Truck (A66736)
2015 Ford F-450...
2008 CATERPILLAR 345C EXCAVATOR (A65056)
2008 CATERPILLAR...
2023 JOHN DEERE 333G SKID STEER (A65053)
2023 JOHN DEERE...
