4110 wont crank
/ 4110 wont crank #1
Gumby542
Bronze Member
Cambridge, VT
John Deere 320
I had it running, today it won't crank. I bolted the seat back on tonight, that was it. I'm guessing it's electrical, a switch not making connection most likely. I hear the seat switch click. It is a 2004 Hydro model. I'm in neutral, pto off, parking brake on. I found 2 black connectors on the left side of the seat, they are both 2 pin black connectors that weren't attached to anything. Could one of these tie to neutral switch on the H//L range selector? Not sure how that reads it's in neutral.
Pto light is off, parking lit brake is on, battery and OP lights on. I just realized I didn't check fuel shutoff valve, but that should crank with it closed, won't it?
Any suggestions would be great
/ 4110 wont crank #2
Make absolutely sure it is in neutral.
I have had the same problem a few times with my 4115 with all this cold weather we've had, and the amount of snow I've been dealing with. The lever looks like it is in neutral, but the thing doesn't do anything. Now that I know that it is just the lever not quite where it needs to be, I bump it and it fires right up. I never had this issue until it got so cold and had all the snow up in around the linkage.
/ 4110 wont crank
Neutral safety switch wire had come off the button switch. Interesting switch style with the buttons.
