4105 Died and won’t start
   / 4105 Died and won’t start #1
SgtSluggo
Bronze Member
Middle TN
John Deere 4105, Ford 1700
A couple of days ago my 4105 died while I was cutting the field and now it won’t start at all
It died like I stood up out of the seat while in gear and now doesn’t even attempt to crank. Battery tests okay and the lights come on. I have triple checked that I am in neutral, the PTO is off, and I am in the seat.
I don’t know what else to check or try and I would really like to get it out of the field.
   / 4105 Died and won’t start #2
How did you check/test out the battery? Load test or just volt meter?
   / 4105 Died and won’t start #3
Did you check the wire for the “in seat switch”?
Have a 2520 & it has gotten loose a few times (2 pin slide on connector on bottom left side of chassis on the 2520).
   / 4105 Died and won’t start #4
If the lights come on but starter won't engage I suspect a safety switch is not satisfied. It could be a bad switch or the wiring to it.
   / 4105 Died and won’t start #5
You said lights come on. Does this include the lights in instrument cluster? Have you checked for blown fuses?
Just a volt meter. I finally got the tractor jumped off and back to the house. Battery reads 12.6-12.7 volts but tractor still makes no attempt to start. Pulled the battery and plan to take it to get tested/replaced.
I did check the seat switch. I finally got it jumped and moved, so I assume all the safety switches are working okay now
Front lights come on. My instrument cluster is completely non-functional. I did end up having a bad fuse (F05 - Ignition Run Power) and replaced it. Hopefully a battery replacement will get me back to working.
2012 DOOSAN G25 GENERATOR (A58214)
2012 DOOSAN G25...
2020 DRAGON ESP...
2013 KENWORTH T880 HYDRO EXC VACUUM TRUCK (A59823)
2013 KENWORTH T880...
2017 Nissan Altima 4 door (A56438)
2017 Nissan Altima...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
RAKE ATTACHMENT FOR MINI EXCAVATOR (A58214)
RAKE ATTACHMENT...
