4105 Died and won’t start
/ 4105 Died and won’t start #1
SgtSluggo
Middle TN
John Deere 4105, Ford 1700
A couple of days ago my 4105 died while I was cutting the field and now it won’t start at all
It died like I stood up out of the seat while in gear and now doesn’t even attempt to crank. Battery tests okay and the lights come on. I have triple checked that I am in neutral, the PTO is off, and I am in the seat.
I don’t know what else to check or try and I would really like to get it out of the field.
/ 4105 Died and won’t start #2
How did you check/test out the battery? Load test or just volt meter?
/ 4105 Died and won’t start #3
Did you check the wire for the “in seat switch”?
Have a 2520 & it has gotten loose a few times (2 pin slide on connector on bottom left side of chassis on the 2520).
/ 4105 Died and won’t start #4
If the lights come on but starter won't engage I suspect a safety switch is not satisfied. It could be a bad switch or the wiring to it.
/ 4105 Died and won’t start #5
You said lights come on. Does this include the lights in instrument cluster? Have you checked for blown fuses?
Just a volt meter. I finally got the tractor jumped off and back to the house. Battery reads 12.6-12.7 volts but tractor still makes no attempt to start. Pulled the battery and plan to take it to get tested/replaced.
I did check the seat switch. I finally got it jumped and moved, so I assume all the safety switches are working okay now
Front lights come on. My instrument cluster is completely non-functional. I did end up having a bad fuse (F05 - Ignition Run Power) and replaced it. Hopefully a battery replacement will get me back to working.
LP Tank (A64119)
LP Tank (A64119)
UNUSED ATS POWER ATS-PC90 HEAVY DUTY PLATE COMPACT (A64281)
UNUSED ATS POWER...
Challenger MT800 Series Service Manuals Vol. 1 and Vol. 2 (A63117)
Challenger MT800...
Deutz F3L912 3-Cylinder Air-Cooled Diesel Engine - 48 HP - Industrial Pump Takeout (A63689)
Deutz F3L912...
2006 Ford F-250 4x4 Crew Cab Pickup Truck (A61573)
2006 Ford F-250...
UNUSED (15) SDLANCH PROTECTION MATS (A64281)
UNUSED (15)...
