4110: Stop washing it???
   / 4110: Stop washing it???
Georgia Boy said:
Leave it running when you wash it and when you get to the short you will know it.
Nope. Once it is running, it stays running. :cool:
Dougster
   / 4110: Stop washing it??? #12
Dougster,
If it's just dust you're washing off, you could also use compressed air to clean the tractor off with... but that doesn't work so well with mud :eek: :p
xlr82v2 said:
Dougster, If it's just dust you're washing off, you could also use compressed air to clean the tractor off with... but that doesn't work so well with mud :eek: :p
It is mostly dust (especially lately with almost no rain around), but a leaf blower alone won't do the trick and shop-type compressed air is simply not available on most of my jobsites. Water, however, is almost always somewhere nearby.
But this kinda misses the point. I really do need to find out what is causing mere water to stop the Red Beast from starting. This is no big deal for one and two day jobs where washdown is done after the fact back at home... but it is a real embarrassment when washdown is required at a client's location... and then I need to spend 30 minutes or more drying everything bone dry before it will start again. :rolleyes:
Dougster
   / 4110: Stop washing it??? #14
Doug,
When your tractor doesn't start, does the engine not turn over or does it turn over and not start.
LAWALLSTRACTOR said:
Doug, When your tractor doesn't start, does the engine not turn over or does it turn over and not start.
When the tractor is soaking wet after a good wash... and I insert and turn the key... I get absolutely nothing. No clicks, no turnover... no nothing.
30 +/- minutes later after I have dried everything out, it starts up just like brand new... and continues to do so until the next wash.
Dougster
   / 4110: Stop washing it??? #16
With no noise at all, I'd be inclined to look closely at the safety switches. My hydro has one on the brake. Does yours have one on the clutch, PTO, or seat?
   / 4110: Stop washing it??? #17
Doug,
First check and clean your battery cables on both ends and see what that does. I would clean all of the connections on the starter solonoid. Try that and let us know what happens.
   / 4110: Stop washing it??? #18
Dougster
Dougster I am cleaning up my old crawler and 300 as well and I pressure washed them. Guess what? Neither of them run now. So far I have pulled the dist on the crawler and it needed many parts replaced from age and water. Don't know on the 300 yet. They both turn over though, just no 6 volt positive sparky :)
   / 4110: Stop washing it??? #19
Dougster
I see... I was thinking that you were doing all your washing at home...:eek:
I can see that it would be kind of embarrasing when/if your tool doesn't come to life and perform as expected ;)
:p
Clutch and PTO for sure... Seat? I'm not so sure. But like you, my first suspicion is those permissive switches... and, in particular, the PTO push-button switch. :rolleyes:
Dougster
2015 Takeuchi TW65 Series 2 (A47384)
2015 Takeuchi TW65...
Excavator Mulching Head (A50774)
Excavator Mulching...
2018 Sakai SW990-1 Tandem Vib Roller (A52384)
2018 Sakai SW990-1...
1985 Toyota Pick Up Truck (A50515)
1985 Toyota Pick...
2004 CATERPILLAR 963C CRAWLER LOADER (A51242)
2004 CATERPILLAR...
