4110: Stop washing it???
   / 4110: Stop washing it??? #1
Dougster
MA
2004 Mahindra 4110 w/509 BH
Recently, my 2004 4110 has developed a bad habit of not starting after being pressure-washed or even rinsed off with a garden hose. Now I know that a lot of you folks are going to write back and tell me to simply stop washing it... :rolleyes: ...but I do prefer a clean machine! :)
Almost every time I wash it now, it refuses to start or even give a good click of the ignition key until everything is bone dry again. Then it starts up fine just like nothing ever happened... and continues to start just fine until the next wash.
What is going kaput or shorting out or maybe dirty/corroded here: The ignition switch? The starter solenoid? One of the permissive switches? Possibly even the alternator, battery or the starter itself??? :confused:
Help! :eek:
Dougster
   / 4110: Stop washing it??? #2
Obviously, you have some moisture in your electrics. When I was last poking around under the 7520 bonnet :) checking out a headlight problem, I saw that the fusebox and the relay box are not tightly sealed. It would be easy for some water spray to get in there and dampen 'em. Same maybe for the panel switches. That should short something out--especially a relay--and you'll get a no start until they're dry.
Moisture in your ignition wires could do this, too.
Next time you wash, take a hair drier to you fuses and relays and see.
   / 4110: Stop washing it??? #3
Dougster,
How about just using a water hose with a spray nozzle (it's all I use) and keep the spray away from the hood, side panels, and instrument panel. No pressure washer. But you will use more water and it takes more time when you have been playing in the mud. :D
hugs, Brandi
   / 4110: Stop washing it??? #4
Next time you wash it, wash one area, then check to see if it starts... If it does, then you know that wasn't causing the problem... isolate the problem by process of elimination.
If you are using a pressure washer, be sure to re-grease all of your FEL/BH pivot points, etc... basically the whole tractor. That high pressure water can get in there and then be trapped by the grease, if it doesn't completely remove the grease in some areas.
Pressure washers are baaaaad... But they sure work wonderfully:eek:
Brandi had the best advice for the sake of your machine since you want to keep a clean machine for your business...
   / 4110: Stop washing it??? #5
Dougster
Have you ever had it in a heavy rain storm? If that shuts her down it might be a really good idea to find the problem.
Cheers
ps7520 said:
Obviously, you have some moisture in your electrics. When I was last poking around under the 7520 bonnet :) checking out a headlight problem, I saw that the fusebox and the relay box are not tightly sealed. It would be easy for some water spray to get in there and dampen 'em. Same maybe for the panel switches. That should short something out--especially a relay--and you'll get a no start until they're dry. Moisture in your ignition wires could do this, too. Next time you wash, take a hair drier to you fuses and relays and see.
I didn't think that water alone could cause a short that would, in turn, stop the Red Beast from starting or even giving me the infamous "click" when I turn the key (i.e., indicating power available). You may be right... maybe the Red Beast needs its own hair dryer! :eek:
Dougster
bindian said:
Dougster, How about just using a water hose with a spray nozzle (it's all I use) and keep the spray away from the hood, side panels, and instrument panel. No pressure washer. But you will use more water and it takes more time when you have been playing in the mud. :D
hugs, Brandi
It makes no difference whether I use the pressure washer or the plain old hose nozzle. Lately, a wet Red Beast is a Red Beast that doesn't start until it is all dried out. And as far as not washing the hood, sides and instrument panel... that where at least half the dirt & dust collects! Half the time I decide to wash it... it's because I can no longer read the dang instruments!!! :eek:
Dougster
Excellent advice! I'll do exactly that... checking the ignition key for the "click" after hosing down each and every area. :)
Dougster
Cheers
Right in the standard terms and conditions of my contract: "For safety reasons, no work (other than emergency work) is performed in the rain."
Besides, once it is running, it stays running! God bless diesel engines! :D
Dougster
   / 4110: Stop washing it??? #10
Leave it running when you wash it and when you get to the short you will know it.
2002 Ford Ranger XL (A50323)
2002 Ford Ranger...
John Deere 9450 Combine (A50514)
John Deere 9450...
New Valley Pioneer SCL850 Mini Skidloader (A50774)
New Valley Pioneer...
2017 GEHL RS5-19 TELEHANDLER (A51242)
2017 GEHL RS5-19...
