4110 linear shift lever
/ 4110 linear shift lever #1
Willman
Southeast PA.
Mahindra 4110
Anybody else have a problem with the linear shift lever too close jamming your left knee? /forums/images/graemlins/confused.gif
Seems like there should be more of a bend in it towards the fender.
/ 4110 linear shift lever #2
In the beginning I knocked it out of gear a couple of times with my knee, but after 85 hrs I am now use to it being there, not a problem now.
Ron
Ron, I should have noted that in mid range its not a problem but in high range and especially low range its right under my knee (seat all the way back).
I was thinking of taking the lever off and giving it a slight bend to the outside some.
Any idea how the lever disconnects?
Would this void warranty for any reason?
/ 4110 linear shift lever #4
Willman
Before you follow any suggestions I give,you should know
1) I'm not a mechanic
2) I'm a first time tractor owner with 85 hrs of tractor experience
I looked at my machine and I did not see any thread where it goes into transmission, I personally would not remove it. if it absolutely must be done I would block it under the fender and bend- with my 4110 there might be 1 1/2" between the shifter and the fender when its in Mid Range. bend it any further and you might not get it into mid range after the bend. My best advice- leave it alone or get your Dealer involved.
Ron.
Thanks for the input Ron.
Im not going to try anything right now. I'll wait till I get back to the dealer and check some other 4110's out to see if other ones are that close. If not I'll ask the dealer what he thinks.
/ 4110 linear shift lever #6
Willman
How did you make out with the Dealer- was he able to adjust the linear shift lever
Ron
I have'nt been there yet, waiting for a wider backhoe bucket to come in and ask him then.
Need to get a oil filter also for 50 hour service, about 30 hours to go!
/ 4110 linear shift lever #8
Not on the 4110, but yes on the 3510. Pretty much the same machine. I have bumped it out of low a few times and have considered bending it back and to the left a bit.
Of maybe put some highway pegs on the frame and ride it like a chopper /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
Ford Tailgate Sign (A64127)
Ford Tailgate Sign...
JOHN DEERE 5100 TRACTOR (A63291)
JOHN DEERE 5100...
Club Car Electric Golf Cart (A66285)
Club Car Electric...
2016 FREIGHTLINER CASCADIA 125 6X4 T/A MID ROOF SLEEPER TRUCK TRACTOR (A59914)
2016 FREIGHTLINER...
Heavy Duty Steel Baskets (A65579)
Heavy Duty Steel...
Brillion Cultamulcher (A66408)
Brillion...
