Oil & Fuel 4110 fuel gauge problem
/ 4110 fuel gauge problem #1
jpifer
Morgantown, WV
I am having an issue with my 4110 fuel gauge. Ignition switch off, gauge reads empty. Ignition switch on, gauge reads full regardless how much fuel is in the tank. I replaced the float assembly thinking that was the issue, but the problem is still there. Is there anything I can do with the fuel gauge in the dash since it is part of a sealed dash unit? I am not buying the entire dash cluster, way too much $$ and the fuel cap is right there in front of me, easy enough to unscrew and look inside. But if anyone else has experienced this and has a solution I would love to get it working.
Thanks,
Jeff
/ 4110 fuel gauge problem #2
Welcome to TBN Jeff:D
I don't have time now, but will look on my FSM CD later to see if I can help you at all.
/ 4110 fuel gauge problem #3
Let's see if you can read this. It's the test procedure for the Fuel Sender.
/ 4110 fuel gauge problem #4
Thanks Kenny. I can read and it and print it off as well. I will give it a whirl while I am off work over Christmas. I hope it is something simple like a loose ground. I hate to think the new float assembly/sensor I put on has an issue like the one it replaced. Then again, if it is a ground issue, the original float may still be good. Shade tree wrench twisting at it's finest.:rolleyes:
/ 4110 fuel gauge problem #5
That's weird. I typed the first thread at work and it must have logged me in under an old log on. That was from my pre-tractor silent observer of postings past.:D
/ 4110 fuel gauge problem #6
Dual Personality aahh?:D
Glad to help...
/ 4110 fuel gauge problem #7
Maybe that is what happened to the fuel gauge, my alter ego broke it! :D
Kelly-Creswell Model C Walk Behind Paint Striper (A66734)
Kelly-Creswell...
CAT R550/D11R Ripper Teeth (8) (A68134)
CAT R550/D11R...
3147 (A63117)
3147 (A63117)
Asphalt Roller Tire (A68134)
Asphalt Roller...
2014 MAC FLAMELESS HEATER TRAILER (A67714)
2014 MAC FLAMELESS...
2013 CHEVROLET 2500 HD (INOPERABLE) (A67714)
2013 CHEVROLET...
