Oil & Fuel 4110 fuel gauge problem
/ 4110 fuel gauge problem #1
jpifer
Morgantown, WV
I am having an issue with my 4110 fuel gauge. Ignition switch off, gauge reads empty. Ignition switch on, gauge reads full regardless how much fuel is in the tank. I replaced the float assembly thinking that was the issue, but the problem is still there. Is there anything I can do with the fuel gauge in the dash since it is part of a sealed dash unit? I am not buying the entire dash cluster, way too much $$ and the fuel cap is right there in front of me, easy enough to unscrew and look inside. But if anyone else has experienced this and has a solution I would love to get it working.
Thanks,
Jeff
/ 4110 fuel gauge problem #2
Welcome to TBN Jeff:D
I don't have time now, but will look on my FSM CD later to see if I can help you at all.
/ 4110 fuel gauge problem #3
Let's see if you can read this. It's the test procedure for the Fuel Sender.
/ 4110 fuel gauge problem #4
Thanks Kenny. I can read and it and print it off as well. I will give it a whirl while I am off work over Christmas. I hope it is something simple like a loose ground. I hate to think the new float assembly/sensor I put on has an issue like the one it replaced. Then again, if it is a ground issue, the original float may still be good. Shade tree wrench twisting at it's finest.:rolleyes:
/ 4110 fuel gauge problem #5
That's weird. I typed the first thread at work and it must have logged me in under an old log on. That was from my pre-tractor silent observer of postings past.:D
/ 4110 fuel gauge problem #6
Dual Personality aahh?:D
Glad to help...
/ 4110 fuel gauge problem #7
Maybe that is what happened to the fuel gauge, my alter ego broke it! :D
2017 CATERPILLAR 335FL CR EXCAVATOR (A65056)
2017 CATERPILLAR...
953D GP Bucket (A68134)
953D GP Bucket...
2020 PETERBILT 367 (A65643)
2020 PETERBILT 367...
2024 CATERPILLAR 239D3 SKID STEER (A65056)
2024 CATERPILLAR...
PORTER CABLE AIR COMPRESSOR (A68842)
PORTER CABLE AIR...
2018 GENERAC MOBILE PRODUCTS MLT6S (A68842)
2018 GENERAC...
