4035 HST low range wont engage
/ 4035 HST low range wont engage #1
landman
Bronze Member
hartford maine
5045e John Deere 520m loader.have owned these others Mahindra 4035 hst 4wd John Deere 4044m hydro John Deere 970 gear
Ive got a 4035 hst that is misbehaving,, low range was popping out on me this fall and now wont engage at all,, not a big deal for plowing but now that i want to use it for heavier jobs I need low range,, Didnt know if other people were having this issue, and how to fix it,, im sure there is a linkage that needs adjusting,,, and also has anyone had issues with hydrolic leaks,, looks like there is a manifold or something up above and to the right of the large filter its leaking down all over the place,, needs to be tightened or is it a problem with the hoses,, had to change out all the diesel lines,, the INDIAN lines they use suck and are not compatible with our diesel, what i was told,,
/ 4035 HST low range wont engage #2
Rubber hose is a good idea but they have updated hoses for some 35seires models.. your dealer should be able to pull up the bulletin...
As far as the range not engaging I would assume something is going on with the shifting linkage... if something took a hit and is warp just a bit it wont fully let it slide into gear.. may check and see if there is any type of adjustment on the linkage also.. I doubt its anything serious but may need to take a few things off to see the full problem
