4035 HST low range wont engage
   / 4035 HST low range wont engage #1
landman
hartford maine
5045e John Deere 520m loader.have owned these others Mahindra 4035 hst 4wd John Deere 4044m hydro John Deere 970 gear
Ive got a 4035 hst that is misbehaving,, low range was popping out on me this fall and now wont engage at all,, not a big deal for plowing but now that i want to use it for heavier jobs I need low range,, Didnt know if other people were having this issue, and how to fix it,, im sure there is a linkage that needs adjusting,,, and also has anyone had issues with hydrolic leaks,, looks like there is a manifold or something up above and to the right of the large filter its leaking down all over the place,, needs to be tightened or is it a problem with the hoses,, had to change out all the diesel lines,, the INDIAN lines they use suck and are not compatible with our diesel, what i was told,,
   / 4035 HST low range wont engage #2
Rubber hose is a good idea but they have updated hoses for some 35seires models.. your dealer should be able to pull up the bulletin...
As far as the range not engaging I would assume something is going on with the shifting linkage... if something took a hit and is warp just a bit it wont fully let it slide into gear.. may check and see if there is any type of adjustment on the linkage also.. I doubt its anything serious but may need to take a few things off to see the full problem
2010 CHEVROLET SILVERADO 3500 (A52472)
2010 CHEVROLET...
2014 Landoll VT-Plus (A52349)
2014 Landoll...
2012 JACK COUNTY 130BBL VACUUM TRAILER (A52472)
2012 JACK COUNTY...
2017 Club Car Carryall 300 Utility Cart (A51691)
2017 Club Car...
2013 PETERBILT 367 (A52472)
2013 PETERBILT 367...
