4.5 grinder recommendation?
/ 4.5 grinder recommendation? #1
herm0016
Platinum Member
Carter lake, Colorado
Branson 4720h
finally wore out my slim grip rigid 4.5 grinder.
I really liked the trigger setup and grip on this, but do not see any like it now.
thinking about getting a made in Germany metabo. any other recs? seems like in the 100ish dollar price point, you can get about any of them. I am a fairly light user, but appreciate a quality piece. never really felt like i needed a ton more power with the orange one, rated at 7 amps. Metabo rated at 8.5. the 11 or 15 amp rated ones look quite a bit heavier/larger on the grip.
/ 4.5 grinder recommendation? #2
I have a DeWalt DWE402W and really like it. I had a 7 amp (I think) Black and Decker Firestone before which was nice, but the DeWalt just never runs out of power...
Aaron Z
/ 4.5 grinder recommendation? #3
Like wow man, the colors!!!1
It's weird enough to see a post come up on another tractor board, but to see it on a completely different topic board is like really farrrrr out man!!!
/ 4.5 grinder recommendation? #4
had something i bought at a partsarama 20 plus years ago, the cord/motor connection got funky, spent $10 w/ coupon at harbor freight...seems fine to me. came with wrench and spare brushes.
/ 4.5 grinder recommendation? #6
In 4.5 inch grinders my fave would be the 10 amp Makitas but my 8 amp Walter is pretty nice too with a slimmer grip.
are you on anandtech? whats your handle over there?
/ 4.5 grinder recommendation? #9
Check out the variable speed grinders too. They have their place for cleaning and finishing. Gives you that variable speed type of feel.I have a Walter that has variable and it has been great.
/ 4.5 grinder recommendation? #10
From what I’ve seen their are 3 types of triggers. That will be your big ergonomic factor. The way the guard works is also a factor- some have quick swivels and some require some effort to move. Beyond that I haven’t seen anything that will significantly outdo another. The 4.5” grinders with soft start feature probably won’t really make much difference....but maybe something to think about.
/ 4.5 grinder recommendation? #11
Regarding types of triggers.
I like slide switch locked on for grinding wheels and cupped wire brush and paddle switch for zip cut wheels and circular type wire brush.
/ 4.5 grinder recommendation? #12
Before I retired I noticed Metabo was the grinder of choice for the Boilermakers who did the outage work in our plant.
/ 4.5 grinder recommendation? #13
I have three on my bench and a new spare in the cupboard. I don't know if it is the amperage (10) or the brand, but I like my DeWalts. When I retired, I gave my Makita and something else to my kids as they felt under powered and I no longer needed them as spares.
/ 4.5 grinder recommendation? #14
It's been a few years since I was working on air tools, but the best by far, and of course most expensive, were the Sioux tools, including their grinders.
/ 4.5 grinder recommendation? #15
I have 3 with the Dewalt being the best built and most expensive of them all. One of them is a HF model and it is significantly lighter but has held up for many years and works as well as the Dewalt. These are used in a hobby environment, not in any kind of professional capacity.
/ 4.5 grinder recommendation? #16
I'm a fan of buying 5 cheap Harbor Freight grinders for the price of a single nice grinder. At $20 each they are disposable & you can have a few with different wheels on ready to go without grabbing wrenches.
/ 4.5 grinder recommendation? #17
I have 2. one is a 4.5" and the other is a 9". they lasted 3 years so far, the 4.5" has plenty of power, but the 9" can't be stopped by anything!.. I only buy good quality wheels, though. they out last the Harbor Freight wheels by a good margin!..
harbor freight consumables are junk. i found a dewalt sale at a local murdochs, and got a great deal on dewalt wheels and stuff, so i have a good stock of them now.
kept being tempted by the metabo, so ordered that one. thanks for the recs though. i may pick up a VS one as well, sounds interesting. have not used one before.
/ 4.5 grinder recommendation? #19
Couple of thoughts. Welder ueses
Metabo...
I have had many years with my made in USA Milwaukee.
Harbor Freight 3 strikes for neighbor and his gate project... the wire cup attachment destroyed all in minutes
/ 4.5 grinder recommendation? #20
HF 11 amp grindet
BOBCAT CT4058 TRACTOR (A64280)
BOBCAT CT4058...
2019 HYUNDAI V12530152-AJS DRY VAN (A59912)
2019 HYUNDAI...
CATERPILLAR 573C FELLER BUNCHER (A64276)
CATERPILLAR 573C...
UNUSED WOLVERINE MSG-11-44W-44" GRAPPLE (A64281)
UNUSED WOLVERINE...
(2) BUCKETS OF ASSORTED ROOFING NAILS (A64281)
(2) BUCKETS OF...
KMC 6-36 (A64119)
KMC 6-36 (A64119)
