DR Power Stump Grinders
/ DR Power Stump Grinders #1
Old Red
Platinum Member
Western Kentucky
Kubota M6800 HDC
About a month ago I brought up in a thread on here a DR Power Kinetic Log Splitter vs a Home Depot log splitter. I went with the DR Power and couldn't be happier with it. It's a little splitting beast. Please remember this....... I am an OCCASIONAL use user.
Anyway, back in 2013 I was sawing down trees here at the house and cleaned out an area. Rented a very nice toro log splitter on tracks for $275. Probably ground out about 15 stumps. The closest place for me to rent a log splitter is about an hour and ten minutes away. If I do the $275 dollar over the weekend thing I have to turn in vacation time for the Friday afternoon pickup and the Monday morning return. I get to put a max of 10 hours on it. This is a commercial very nice stump grinder on tracks. Works great but very inconvenient and requires vacation and quite a bit of Tavel.
Now in this scenario where I rented a machine, if I take the grinder back on Monday, then on that same Monday night I have a tree die or fall over then I am SOL cause the stump grinder is 1 hour and 10 minutes away and another $275 rental fee.
The DR I was looking at is a homeowner grade stump grinder. About 1700 bucks. The benefit of it is that I would have a stump grinder the rest of my life sitting in my garage, can pick and choose when I want to drop trees and not really have to think about it....I have had a dead one now for a couple years making a mess on my driveway but didn't want that darn stump to deal with. I finally cut it down so here we are and I am now going to start dropping the rest of the dead tress and trees I wish I would have dropped the first time around as well as the ones in the way of my sons basketball court. I really am trying hard now to not add any additional engines, tires, batteries, spark plugs etc. to my arsenal of equipment. I don't want to set myself up for more complication as I get older which played into the factor of purchasing the electric kinetic splitter. So anyway, Dr Power little cheaper stump grinder that will get the job done when I need it on occasional use. (like my wood splitter) or rent an awesome one for $275.
I am leaning toward the Dr Power to have one here at my disposal to use for the rest of my life. Any thoughts? Anyone used a DR Power stump grinder? As with the DR K10 Splitter there are tons of glowing reviews about it. And I was very skeptical on my splitter but am convinced now.
/ DR Power Stump Grinders #2
I'm in the rental crowd. Time your tree cutting operations so that you have a bunch of stumps ready then go rent the thing for the weekend. If you buy one then you inevitably will have to work on it because it won't start when you want to use it because it sat around with ethanol gas in it. You'll have more room in your garage/shop/barn because you won't have to store it.
I just get sick of having to fix junk every time I want to use it. With a rental you're pretty much guaranteed it will work when you turn the key. Just my opinion...yours and others may differ.
/ DR Power Stump Grinders #3
I bought the 14hp model sans the extra bling. I can pull it around the yard with the EZ-GO by holding the handle offset just right and turning only to the left. :laughing:
Anyway, here are two pics taken 23 hrs apart. Jon is pushin' 68, stands 6' 2" and weighs 170lbs, no linebacker, he. The Poulan "Wild Thing" has an 18" bar, and the bike's wheels are 26" type. I shoveled-up nine 5 gal buckets (right after the second pic) and still left a mess. Best to haul off as much chips as is easy because when left they will suck nitrogen until they are thoroughly blackened and unrecognizable. (add 28N ferts).
I did a maple for a guy that was all of 24" diameter where he cut it off 5 or 6 inches above ground. Beware if you ever charge by the inch diameter (I get free coffee :)) and take that number where the stump breaks the surface. 4" - 6" stumps don't take 10 minutes. Trees set shallow or cut 'tall' (>4") will be a bit of work. You may end up grinding quite a ways out from such to get roots. "Depends on the terrain>"
Easy to spend someone else's bucks too, but suggest that you buy the DR and don't look back. It'll earn it's keep. :cool: I've rented 'junk', but take care of my own stuff (clean off, check fluids, etc ... park some things indoors :eek:) After 20-some stumps of all sizes (and some >2 feet out) it'll take me a while to wear it out. Yeah ok if you buy 'new'.
Did I mention not filling the hole with chips because nothing will grow in that s__?
View attachment 538693View attachment 538694
Easy to spend someone else's bucks too, but suggest that you buy the DR and don't look back. It'll earn it's keep. :cool: I've rented 'junk', take care of my own stuff (clean off, check fluids, etc ... park some things indoors :eek:) After 20-some stumps of all sizes (and some >2 feet out) it'll take me a while to wear it out. Yeah ok if you buy 'new'.
What does "sans the extra bling" mean? Did you get the 14.5 pro or the 16.5 pro? Pull start or electric start? Who is Jon?
So you sound like you are pleased with the DR. That is what I am reading on the DR website reviews, plenty of pleased buyers. How many stumps have your ground up with it? How long have you had your machine? Have you replaced the teeth yet? How long did it take you to grind up the stump in the picture?
And to poster #2. I am right there with ya 100%. Except the problem for me in this situation is the closest place that rents a grinder is over an hour away. I actually like renting small equipment for the reasons you state. Heck I even rent a power washer once a year but the rental yard that has the washer is literally 5 minutes from my house.
/ DR Power Stump Grinders #5
I got the 14.5 hp without the remote start and cup-holders. Personal info was to assure that I'm old (for my size?) but can muscle the stump grinder without it being on a 3PH or self-propelled. The Stump in the pic took > than 1 hour, but understand that I took several breaks to shovel chips out of the way and/or off-site. IIRC, the second pic was taken just before my final chip-scooping. By then I had 6 or so buckets full, and had dumped/refilled 4 of them once. I got four or more from the garage, and filled them from what's in the pic. What wasn't snow-dampened, later became oil-dry, and the wet was compost. I left more than I wanted to in place, but my topsoil pile was under snow just then.:laughing:
Imagine pushing a walk-behind rotary lawn mower, then raking up as much as you cut. Balance of fun/work is similar and how much of either that is would be very much YMMV. btw, I have little/no cartilage in either knee, no L-5 disc in my back, and the five ribs I broke in 2013 are often sore when I wake up. My point there is that athleticism isn't a requirement, and IMO that should explain we happy DR owners.
So, I've ground maple, fir, and elm in the 14" and up sizes, one or two of each there, way over a dozen ash that were from say 4" to not more than 10". Only the ash were ever cut <4" above their surroundings. The larger trees were always higher up with roots exponentially further out from the bole (trunk). Shallow-rooted willows do that a lot from frost heave, so I suspect those with long taps roots do as well over time.
I'm a retired tool grinder (toolmaker's j-card) and have watched the teeth closely. When installed, they index 120^ apart into one of 3 positions. Whatever grade carbide, (C-6?) they don't seem to chip and haven't noticeably worn, and that elm next to my d'way was plenty gravel-bedded from the place's 3 decades (and >two ago) as a gravel/sand pit.
Anyway, I looked at the faces to see what it's take to 'sharpen up' on my T&C grinder. The teeth are cupped at what I'd guess is ~1' radius (I'll 'gauge' tomorrow) with say a .020" flat to toughen the edges. I'm actually anxious to set up and grind a set (1 1/2" is my smallest dia 'diamond' wheel), but guess if I'm a few dozen trees from even rotating them yet. There a dozen or more elms in my lawn to grind this Summer. Trunks at 3" height run 12" - 22" and one ~28" at that height. I suspect I might rotate the teeth once by then. We'll see ...
OK, tmi, but even banging the 'wheel' on the concrete hasn't nicked a tooth when scooting the stumper in & out of the barn. That kinda surprises me because I always expect it. :rolleyes:
There may be a better long term option, or you might be able to rent one like this, grind your stumps, and return the rental the same day.
WG24 Stump Grinder – Woodland Mills Canada
Oh my! Thank you for this..... Just now opened this and looking over it a little. It appears one reviewer used a subcompact Kubota BX....that is the tractor I have available to me here at the house. I am going to read more bout this in the morning. I wasn't sure if an inexpensive grinder was out there for a subcompact tractor.
/ DR Power Stump Grinders #8
I hired a guy to do some tree work for me. The ash tree was cut down and cleaned up leaving a 24" stump. He came back the next day while I was away, with a rented DR stump grinder. When I got home, he was sitting in the shade with some ice water and a wet towel. He had been grinding on that stump for over an hour. Judging by his progress, it would be another hour before the stump would be completed and it would only be about 2" deep.
I told him to stop working before he hurt himself and that I would call a guy I knew with a 50 hp Vermeer stump grinder. He ground a 12" deep hole and left a giant pile of wood chips the size of my thumb, all in about 10 minutes.
I,ll never operate one with handlebars after watching that.
/ DR Power Stump Grinders #9
There IS another option.. & I hate to write it..
Personally, I would NEVER DO IT..
DR offers a 1 YEAR try it-before you by it.. on a lot of their equipment..
Get it.. use it.. return it..
& you have a whole year to fall all your trees.. lol
I think I have watched every youtube video, read every forum post that pertains to the DR Stump Grinder on the web. The recurring theme over and over is that they will get the job done and a lot of satisfied owners out there. I kind of see it like a "subcompact" stump grinder. None of us would move piles of dirt for a living with our BX buckets but we would sure move a pile of dirt in our own yard. I think the same analogy can be made for the DR Stump grinder. I also like that it is a dedicated machine and I don't have to hook up something else.
I pulled the trigger on the DR Power 16.5 Pro Model. I was all set to purchase the middle model but my motto "buy once cry once" kept going though my head as I was clicking through the screens. The larger unit seems to be 13 horsepower (420cc Briggs) and the middle about 10 horsepower (300cc Briggs). It also comes with electric start and a tow bar. I guess when I'm 70 and grinding stumps I'll be thanking my 43 year old self for getting the Tow Bar and electric start, and hopefully the extra 120cc will get me through stumps faster. I'll be sure to post pictures and my findings here in this thread once I use it some.
/ DR Power Stump Grinders #12
43? Who's 'old', your sentry? (canine) :laughing: I'm 2 years and 2 months away from 70, and only a year-in with the DR, but I'd bet you don't wear yours out by that age. :)
Guys, keep these in mind when stumping, esp with 'walk-behinds', and don't over-think 'em:
- If you don't tire easily, have someone rake chips out of the way as you go so you can see where to move to.
- If you're my age or DO tire easily, you may appreciate a 'rake break' every 15-20 min to clear those chips. ;)
- Don't skimp on digging around each stump before you start, and keep soil separate from chips for less mess and 'cleaner' back-fill.
- Use a 'beater' chain (near its last re-sharpen) to cut the stump fairly close to the ground.
- An extra 4" height on a 24" stump means more work/time and a LOT more chips.
- If you don't have wet pond weeds to add to chips for composting, just add hi-N lawn ferts, topsoil, and water to get it to 'cook' faster.
(.. you knew all that. :) t o g)
As promised here are some pics and thoughts...I received the DR Stump grinder today. Got it inside and put oil and gas in it and took it to a stump to test it out. I am pleased with it. It is not near as good as the rental I used but that thing is a 15 thousand dollar stump grinder. And it actually grinded the stump just the same but just didn't get there and move around on self propelled tracks. I am learning how to operate it and the first stump took about 30 minutes according to my hour meter. If you have any questions, hit me up.
I am glad I have it.
For some reason uploaded files are always upside down or whatever....when you click on them the will be correct.
2018-02-20 11.29.28.jpg2018-02-20 11.50.20.jpg2018-02-20 11.50.14.jpg2018-02-20 17.21.31.jpg2018-02-20 17.00.08.jpg
/ DR Power Stump Grinders #14
View attachment 540891View attachment 540893View attachment 540894View attachment 540896View attachment 540897
Hey, can I borrow that? I ain't that far away up here in Missouri. :laughing:
I just wanted to get in the "first" borrow. I am sure you will hear more from friends and family.
/ DR Power Stump Grinders #15
LOL.!!! "1st" borrow.. Lol..
That's kinda like "trying" to borrow a log splitter..
What's the rules on that....borrowing log splitter and stump grinders etc.? I have been cursed with being a little protective of stuff and that is all good until someone wants to borrow something that can break.
/ DR Power Stump Grinders #17
I would think those type of "borrow" requests should be treated about like a request to "borrow" your wife.
/ DR Power Stump Grinders #18
I'm the "go to guy" when it comes to borrowing tools.. WELL, I should say, "use to be" the go to guy..
I simple say, "Sorry but I don't loan tools anymore".. " but I can offer you a beer"..Lol
THAT usually takes the sting outta the NO & we sit around swapping stories about people breaking YOUR equipment & returning it broken..
I was surfing Amazon the other day & ran across some "stickers".. they were about borrowing tool.. funny as heck..
/ DR Power Stump Grinders #19
A buddy who lives 10 minutes away, wanted to borrow a tool for a job that would take only 5 minutes to accomplish. I handed it to him and said "see you in about 15 minutes". It turns out he was planning to return it in a week or so, until I reminded him of the fact that he stopped working to borrow it and he should be willing to stop working to return it.
He never asked to borrow anything again.
/ DR Power Stump Grinders #20
THATS usually how it goes.. sad but true..
WE COULD start a new thread about "borrowing tools"..
It would have a post count as hi as the "harbor freight" one.. Lol
Congrats on the new grinder Old Red.. sorry for hi-jacking the thread..
