3rd Transmission Fluid Plug?
/ 3rd Transmission Fluid Plug? #1
Hdoilcan
USA
2018 KIOTI CK3510SE CAB, 2475L BACKHOE, 72 BOX BLADE, 72 REAR BLADE, 72 LANDSCAPE RAKE, 1,250 LB 55 GAL DRUM BALLAST, 2018 FERRIS IS 700Z, 26HP 810 VANGUARD ENGINE
I finally got around to doing my 50 hr service on my L3540. I did the oil first.... All went fine. As I'm going to do the transmission fluid change I notice the manual says 3 drain plugs. I found the two towards the back of the tractor but it also shows that there's also one about midway between the rear tires and the front tires. I found where I'm thinking is but I had a 3rd function valve added and there's a hose going from where it looks like the drain plug should be to the 3 rd function valve next to the right hand door. Iv added a pic to show what's there. I'm wondering do I undo this hose and drain it? Or should I just drain the two rear ones?
There was a orange peice of metal protecting the hose and fit fittings.
/ 3rd Transmission Fluid Plug? #2
Just looking at the plate it looks like it is missing half the retaining bolts. Is it? Or am I hallucinating?
Yes I removed 4 bolts that were holding up a "V" shape metal guard protecting this area.
/ 3rd Transmission Fluid Plug? #4
I've got a B3030 and it has 3 drain plugs. I drained all 3 at my 50-hour maintenance interval. Next time, I just draining the center one. The fluid from the 2 side plugs was probably less than a pint each. The more you loosen the more you can strip. My advice would be, if one plug gets most of the fluid, just drain one.
I did get a giid amout from the two side plugs. I just git off the phone with the dealer and he confirmed the center plug is no longer a plug. When they added the 3rd function valve they put a hose connection from the plug yo the valve. He said to just drain from the two rear plugs.
/ 3rd Transmission Fluid Plug? #6
I would think you would get quite a bit to drain from the center plug where they hooked the line to as that was the main drain plug before they did that.
/ 3rd Transmission Fluid Plug? #9
Funny they didn't install a T there so you could still have a drain plug there?
/ 3rd Transmission Fluid Plug? #10
I would pull the hose/adapter and get it all out. You want to change the oil, right? Not just some of it. How much did you get out? If you got 90% out, then fine. If not, I would go the one little extra step and do the job right. Not sure if your capacity is same as my L3940HST, but my drain and refill was 9 gallons 3 quarts. Philip.
/ 3rd Transmission Fluid Plug? #11
Philip8N,
That is good to know as the book says the 3540 holds a little over 11 gallons (44.4 quarts) I was wondering if it actually held that much as we should have the same transmission. I know when I changed the engine oil and filter the book said 7.1 quarts and I got 6.25 quarts in it and it was full. Thanks.
/ 3rd Transmission Fluid Plug? #12
Cautionary Note
Use a torque wrench when retightening your bolts.
429858 (A61165)
429858 (A61165)
2006 Cadillac Superior 6-Door Limousine, Ultra-Low 20396 Miles (A63688)
2006 Cadillac...
1000 GALLON POLY NURSE TANK (A64276)
1000 GALLON POLY...
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2019 CHEVROLET...
2021 Unverferth 432 Rigid 4 Row 36-inch 3PT Ripper Bedder (A63688)
2021 Unverferth...
IMPORTANT PLEASE READ!!!! TERMS AND CONDITIONS (A65583)
IMPORTANT PLEASE...
