3rd Function Hydraulics
/ 3rd Function Hydraulics #1
bud71
John Deere 1070
New to Forums...
Does the following picture show that I am all set to add a 3rd function implement (root grapple) by just adding a controller (also pictured). I am assuming with very limited info that I run lines from the outlets picture to the controller and then from the controller out to the cylinder on the root grapple. Is that all I need?
/ 3rd Function Hydraulics #2
:welcome:
Is that a T or elbow off the couplers? And is it a joy stick SCV controlling the couplers now?
What tractor do you have?
It is a John Deere 1070 and it appears as though they are "T" connections that come off the mid mount SCV.
Sorry forgot to tell you that yes there is a factory joystick that controls the loader functions.
/ 3rd Function Hydraulics #5
Interesting setup... I just got back from Home Depot with some ball valves! Have a water plumbing project.
So, if I had to venture a guess... it looks like the previous owner used the loader boom lift function (or the loader curl function) to operate a log-splitter or some other stationary hydraulic implement.
Turning the ball valves "off" re-routes the hydraulic flow to the Quick Disconnects at the bottom of the "T". After hooking up the male connectors to the QD's - the hydraulic functions can be controlled from the loader joystick on the tractor.
Unfortunately, you cannot simply plumb in a single spool valve from the "T'd" Quick Disconnects and have 3 hydraulic functions. The ball valves limit you to one function at a time - loader flow or QD flow.
There are posts and posts regarding the different approaches that can be taken to achieve multiple hydraulic outlets here on TBN. The JD owning/operating forum is a good place to start - look for posts/threads from Kennyd. Long time contributor on TBN on hydraulics. JJ is another very knowledgeable hand on the subject of hydraulics.
Electric diverters, multiple spool valves using the power beyond circuit - lot's of good ideas - with pictures.
Best of luck.
AKfish
/ 3rd Function Hydraulics #6
What pressure does your tractor's hydraulic system operate at? I doubt those ball valves from Home Despot are rated for the pressures commonly found in hydraulic systems. I know I wouldn't use them, especially if they are the Made in China variety with the mystery-metal they use over there.
If you're new to hydraulics, read up on how and why to avoid hydraulic fluid injection injuries.
/ 3rd Function Hydraulics #7
Dittto above post. I would want steel valves, rated above system pressure.
I did not put them on it was that way when I bought it...but I think I am getting a better understanding of what they did based on what you guys have said. In reality I do not have the capabilities to have the third function without adding a diverter. This system as they created it simply re-routes one of the factory scv remotes for another function it does not add another function.
/ 3rd Function Hydraulics #9
I would still change the brass valves for steel before they fail and cause an injury. You can NOT be too careful when it comes to high pressure hydraulics.
/ 3rd Function Hydraulics #11
You have a diverter, it's manual :)
Those ball valves jumped right out at me too. even steel plumbing fittings, designed for water service are frowned upon by those that know hydraulics.
A brass housed valve looks like an accident waiting to happen.
What could those things be designed for 250psi max ???
JB
/ 3rd Function Hydraulics #12
JB
If you see 600 WOG on the casting, it means 600PSI Water-Oil-Gas; but 600PSI is far from the ~2,000+ PSI rating of most hydraulic systems. The valves could say 150 WOG or 300 WOG, etc; but don't expect plumbing valves to be pressure rated for hydraulic systems. Also temperature affects the pressure rating, and I suspect hydraulic systems at operating temperature run hotter than your average Domestic Hot Water system. Calling those ball valves an accident waiting to happen is being polite.
The other thing the OP needs to know is that hydraulic NPT fittings and plumbing NPT fittings may have the same thread designation and screw together; but the hydraulic fittings have tighter thread tolerances, better materials used in the fitting, better finishing and plating specs and so on.
2018 Tycrop Vector Belt VB-16H Sand Belt (A64194)
2018 Tycrop Vector...
2015 Ford Taurus Sedan (A64557)
2015 Ford Taurus...
2004 Eagle Blue Boat Trailer (A66285)
2004 Eagle Blue...
Pallet of 8ft Metal Roofing (A65583)
Pallet of 8ft...
2021 BOBCAT E50 R2 SERIES EXCAVATOR (A63276)
2021 BOBCAT E50 R2...
Wooden Glider Chair (A64557)
Wooden Glider...
