3rd function control on the Joystick
/ 3rd function control on the Joystick #21
I had to go thru my JD Dealer for the Fasse, as they dont deal directly with the public. I was interested in the WRLong setup, but for some reason my dealer didnt deal with them. The Fasse was more expensive than the Long, total was around $600 I think. But to me the diff is worth it, as if something breaks, I can take it back to the dealer.
I got the ATI grapple thru my Ford/NH dealer, I think it was around $950 delivered. Price of steel had gone up and increased the price. If I were to do it again, I'd buy a grapple bucket off ebay. The ATI is nice, but adds a lot of weight to the bucket for normal use.
The more I have looked at this, I believe that all I really need is a solenoid to actuate the existing third function. So now I am researching solenoids...
/ 3rd function control on the Joystick #23
This is what I am going to use in my grapple set-up. (Copied directly from PineRidges' set-up. /forums/images/graemlins/cool.gif Thanks, PineRidge. /forums/images/graemlins/grin.gif) I like the diverter type the best. It's simple to "toggle" back and forth between fuction using a momentary push-button switch. I also like the fact that I can control the speed of the grapple with the joystick.
/ 3rd function control on the Joystick #24
</font><font color="blue" class="small">( Ok, how does this look:
Part no. 4UB12 )</font>
That should work but that part is a little more expensive since you have to add an additional $32 for the wire plugs bringing the total to over $300. And you still have to buy 4 sets of fittings. /forums/images/graemlins/blush.gif
Keep looking as the Hyvair should be cheaper since you don't need the plugs and Grainger is usually more expensive anyways.
I got my kit which included everything (knob, wiring, fittings, hoses, valve, bracket) for $519 thru the local JD dealer who is also a WR Long dealer. He didn't even mind ordering something for a Kubota either. /forums/images/graemlins/grin.gif
I kind of like the true third function over the diverter. The extra $90 for the setup was worth it, in my opinion.
/ 3rd function control on the Joystick #25
BigDogues thanks for the complement! I like the electric diverter also. Very handy and very easy to use mounted on the joystick. /forums/images/graemlins/cool.gif
Let me know if you need any assistance with your project.
/ 3rd function control on the Joystick #26
I also have been thinking about this...learned a lot here thanks!
Seems like sometimes I might want to use the grapple to just keep something in the bucket, but not crush it.
In this case wouldn't the diverter setup give you more control over the grapple?
For those that have a diverter setup, does the bucket move at all when you switch back and forth?
/ 3rd function control on the Joystick #27
</font><font color="blue" class="small">( For those that have a diverter setup, does the bucket move at all when you switch back and forth? )</font>
Not even a little bit.
HERE is a link to my diverter install.
/ 3rd function control on the Joystick #28
</font><font color="blue" class="small">( wouldn't the diverter setup give you more control over the grapple? )</font>
Either a diverter or a third function will give you the same control over the grapple.
The third function has the advantage of operating the grapple and the lift/curl simultaneously, albeit a little slower. This could be helpful for some situations.
/ 3rd function control on the Joystick #29
Thanks for the price info. The ATI grapple would be simple to install to my rake but for that price I should be able to make on that will best fit my needs.
/ 3rd function control on the Joystick #30
<font color="blue">>>( wouldn't the diverter setup give you more control over the grapple? )</font>
<font color="red">
>Either a diverter or a third function will give you the same control over the grapple. </font>
Seems like you could feather the diverter but the solenoid operated third function is either full on or full off.
/ 3rd function control on the Joystick #31
That's why I went with the diverter for my grapple. I didn't want the grapple beating up my bucket and I wanted a little more control when picking up something that might not exactly be trash.
W.R. Long sells the kits too.
I originally bought a V&M diverter kit through a local dealer, but it is 2 valves with solenoids on each end. Each valve was about the size of the entire diverter from W.R. Long and I didn't like that fact that power always had to be on for either set of ports to work.
The W.R. Long diverter has 1 solenoid and the valve is either on the first set of ports with no power or on the second set with power.
If anyone is interested, I have a V&M diverter kit still in the shrink wrap that I'll make someone a good deal on. The kit is basically the 2 valves and a handle with a switch. I think there are some fittings that get you out of the ports, but without looking at it I am not sure.
http://www.vandminc.com/vmsite/vm/fadd.html
Man Basket Boom Lift Attachment (A64553)
Man Basket Boom...
44in Single Cylinder Grapple Bucket Skid Steer Attachment (A64553)
44in Single...
2016 CATERPILLAR 303.5E2 CR EXCAVATOR (A65053)
2016 CATERPILLAR...
2017 Mack Semi (A64047)
2017 Mack Semi...
John Deere 5220 53HP Loader Utility Tractor (A64194)
John Deere 5220...
2015 CATERPILLAR TH255C TELESCOPIC FORKLIFT (A65053)
2015 CATERPILLAR...
