3rd & Final Pic for Now
/ 3rd & Final Pic for Now #11
</font><font color="blue" class="small">( SIDE NOTE--Is this muffler USDA approved as far as being a spark arrestor? The last person careless with fire in our part of the country burned 100,000 acres. Yes, that is One Hundred Thousand acres.
)</font>
THAT'S the muffler? Heh. Did they weld that up on their own or something? I believe it will be stamped into the metal of the muffler if it is approved as a spark arrestor. That's how it was on the dirtbike I used to ride in the woods when I was much younger.
If I ever get around to getting my PT (next year?) I might consider swapping in an offroad motorcycle muffler. I'd rather that the exhaust shot out the back then the side. Although the side is better than my lawn tractor that shoots it out the front so I get to drive through it for 2 hours at a time! /forums/images/graemlins/mad.gif
/ 3rd & Final Pic for Now #12
I had the same question for Terry about the grease fittings.
He told me the manual covers several models. Yours and mine have two points to grease on the lift arms and three at the center. Terry says the two towards the back get a lot of use and should be greased every 8 hrs. The other one under the plate which has no fitting in the hole can be greased every 50 hrs. Dry lube for the rest of the joints every 8 hrs.
sg
/ 3rd & Final Pic for Now #13
</font><font color="blue" class="small">( I had the same question for Terry about the grease fittings.
sg )</font>
Roger that - anyone who has used the PT for any amount of time will see how crucial greasing the joints that provide the articulation and oscillation is so crucial - without proper lube, these would fail in a hurry. So, grease-em-up!
-Rob /forums/images/graemlins/grin.gif
</font><font color="blue" class="small">( THAT'S the muffler? Heh. Did they weld that up on their own or something? I believe it will be stamped into the metal of the muffler if it is approved as a spark arrestor. That's how it was on the dirtbike I used to ride in the woods when I was much younger. )</font>
I just discovered that the muffler pictured (and its 'jacket') are actually made by Kohler!
Seems much sturdier than most Kohler exhaust systems, but it matches the construction of the rest of the machine.
I agree about the exhaust location. I think I'll just cut a hole in the expanded metal and maybe use a short, easily removable pipe to extend it out of the engine compartment.
I've done this before on other equipment. The downside is that when you have to remove a short pipe to open the engine compartment, you MUST remember that it's hot. Only forgot that one time. Experience is a great teacher! /forums/images/graemlins/grin.gif /forums/images/graemlins/blush.gif
Mark H.
/ 3rd & Final Pic for Now #15
I don't think that extending the muffler pipe out past the cage will do that much to reduce heat in the engine compartment. When the engine is running at high throttle, the force is sufficient to blow it out. Also, the motion of the tractor coupled with the open cage on all sides will let enough air in to take the heat away. Just my opinion. /forums/images/graemlins/wink.gif
Only way to prove it is to take heat measurements under controlled conditions both before and after the modification.
/ 3rd & Final Pic for Now #16
</font><font color="blue" class="small">( The downside is that when you have to remove a short pipe to open the engine compartment, you MUST remember that it's hot. Only forgot that one time. )</font>
I'm thinking more along the lines of cutting a slot so you can still open the engine cover without having to remove anything. Of course, I don't have one of these so I can't really comment on the difficulty of this modification. /forums/images/graemlins/wink.gif
/ 3rd & Final Pic for Now #17
</font><font color="blue" class="small">( I don't think that extending the muffler pipe out past the cage will do that much to reduce heat in the engine compartment. When the engine is running at high throttle, the force is sufficient to blow it out. Also, the motion of the tractor coupled with the open cage on all sides will let enough air in to take the heat away. )</font>
I agree with Moss. Air is being moved by multiple forces. There is the intake, the engine cooling fan, the hydraulic oil cooler fan, the exhaust blast, the motion of the machine itself, and convection.
As evidence of this, I offer our experience. When we are cutting, a <font color="red"> lot </font>of dry grass from previous mowings ends up being sucked into the engine compartment. It is everywhere--proof positive of air circulation back there.
It also keeps us on our toes, as the stuff that lands on the muffler tends to catch fire after we shut down. /forums/images/graemlins/crazy.gif See the last couple of paragraphs of this post for more info.
SnowRidge
/ 3rd & Final Pic for Now #18
</font><font color="blue" class="small">( I just discovered that the muffler pictured (and its 'jacket') are actually made by Kohler! )</font>
How did you find that out, Mark? It looks like the same muffler we have (sans jacket), and we were told PT built them themselves.
SnowRidge
/ 3rd & Final Pic for Now #19
<font color="red"> you MUST remember that it's hot. Only forgot that one time. </font>
An oft-repeated statement comes from an old drag rcing incident. A passerby picked up a clutch disk that had just been removed from a car by a frantic crew trying to ready it for a run. When he promptly dropped it, one of the mechanics said "Hot, huh?" The reply: "No, it just doesn't take me long to look at one of those." /forums/images/graemlins/grin.gif
Snowridge-
</font><font color="blue" class="small">( How did you find that out, Mark? It looks like the same muffler we have (sans jacket), and we were told PT built them themselves.
)</font>
At this point, I'm not actually sure that I'm correct. I'm only going by what the PT manual says (calls it 'by Kohler') and the large welded letter 'K' on it.
How much of what the manual says should I believe? I'm a bit skeptical about some of it, for instance, there are two paragraphs in one section (one right after the other) that each specify a different hydraulic oil weight.
Mark H.
2022 John Deere R4023 (A60462)
2022 John Deere...
2013 Freightliner M2 106 Altec TA45M 44ft. Insulated Bucket Truck (A60352)
2013 Freightliner...
2005 DRAGON ROLL-OFF  TRAILER (A60736)
2005 DRAGON...
500BBL SKIDDED FRAC TANK (A58214)
500BBL SKIDDED...
2021 MULTIQUIP WHISPER PORTABLE AC GENERATOR (A59823)
2021 MULTIQUIP...
excavator trenching bucket- one bucket per lot (A61307)
excavator...
