3pt Top Link chain
/ 3pt Top Link chain #23
I rarely hook up the toplink to either the finishing mower or the bush hog. If there's a rock to hit, lifting the 3 point hitch gets it over any obstacle.
My 3 point hitch holds it's position quite well, no drop so no worries...
What does that do to the PTO shaft U-joints?
/ 3pt Top Link chain #24
After reading about guys using a length of chain top link, I made one. I considered what happens if the mower or land plane tips up all the way. My rotary mower would tip up to about 60° before the A-frame hits the back of the tractor diff. housing, but by then the PTO shaft has already broken, which I should've already known and shut down the tractor. Using a short pipe 6" shorter over the chain prevents this from happening.
I wonder how many tractor operators don't watch the implements they are using, just turn the key and steer? This can cause problems though, I have a loose disc in my back from looking over my right shoulder watching what's happening; my chiropractor fixes me about 1-2x/week.
What I need is a chiropractor to fix me at least weekly but it has to be a young she with tight fitting clothes as well..
/ 3pt Top Link chain #25
I went to one once, it made me stiff in the wrong places; never went back.
/ 3pt Top Link chain #28
Don't really know, never a problem for me. Plenty of overlap but not enough to ever bottom out. The pto shaft and 3 point hitch arms are pretty parallel and only a few inches higher. So nothing gets into a bind no matter how deep a ditch I cut across.
As for the OP, not sure chains are recommended for any other implement except for mowers...
All., thank you! keep the comments coming. About 80% of my mowing is done going backwards. I live in a holler and to keep the roads and ditches clean its usually a case of backing the mower over the edge back and forth all the way, thank God for HST. I know that is not the intended design of a rottery cutter. But i dont have a flat peice of ground on this place except where i have made it flat. How do you thing using a chain would work out mowing backwards.
(INOP) 2012 DODGE CHARGER (A59823)
(INOP) 2012 DODGE...
2017 Kubota SVL75-2 (A60462)
2017 Kubota...
2021 Kubota RTVX1140 (A60463)
2021 Kubota...
Bush Hog RDTH84 (A60462)
Bush Hog RDTH84...
8' DISC HARROW (A60430)
8' DISC HARROW...
2014 FORREST RIVER SALEM TRAVEL TRAILER (A55745)
2014 FORREST RIVER...
