3pt lift
/ 3pt lift #1
ac450
Thomasville NC
MF 1020
I just got a MF 1020 that had been sitting for 4 or 5 years I have it running but the 3 point will not work? I have turned the knob fully both ways any help on what to do next would be nice Thank you!
/ 3pt lift #2
First change the hydraulic fluid and see if that helps.
/ 3pt lift #3
You need to find out if the pump is pumping, and with the hard lines running all the way from front to back it might be hard to unhook at the rear to check for flow. If it has the oil cooler there are some connections there you might unhook and check for flow. The pump isn't hard to pull to check shaft, the inlet hose is short and stiff that might be a bear. I can't remember a place that a gauge could be hooked up.
New/Unused Landhonor Power Rake (A65583)
New/Unused...
F-150 4WD (A63689)
F-150 4WD (A63689)
2023 SANY SY225C EXCAVATOR (A63276)
2023 SANY SY225C...
38ft Vulcan Lowboy Trailer (A65563)
38ft Vulcan Lowboy...
2003 International 4300 Flatbed Dump 571559 (A62613)
2003 International...
2014 VOLVO A40G WATER TRUCK (A62129)
2014 VOLVO A40G...
