3pt hitch buming/shaking
/ 3pt hitch buming/shaking #1
lakngulf
Lake Martin Alabama
Kioti CK30
I have a Kioti CK30. At times I raise whatever implement is attached to the 3pt hitch, and it starts bumping.....bump bump bump. A very noticeable shaking.
I lowered and raise a few times and eventually it goes away. Hydraulic fluids seem to be at full on the dip stick. Any ideas what causes this?
/ 3pt hitch buming/shaking #2
Check the hydraulic pressure, sounds like it's too high.
/ 3pt hitch buming/shaking #4
I've had this happen a couple of times on my CK30. You need to adjust the MLS control valve (control sensitivity adjustment). If that doesn't solve it, unfortunately you'll have to replace it (sticker shock) as you can't rebuild them.
Informational Lot - Shipping (A63688)
Informational Lot...
New/Unused ATS T460 Mini Skidsteer (A65583)
New/Unused ATS...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A64276)
KNOW BEFORE YOU...
2016 Ford F-150 4wd 4 Door (A63689)
2016 Ford F-150...
2020 Bobcat MT85 (A62177)
2020 Bobcat MT85...
2020 HYDREMA 922G HM ARTICULATING DUMP TRUCK (A65053)
2020 HYDREMA 922G...
