3pt hitch buming/shaking
/ 3pt hitch buming/shaking #1
lakngulf
Lake Martin Alabama
Kioti CK30
I have a Kioti CK30. At times I raise whatever implement is attached to the 3pt hitch, and it starts bumping.....bump bump bump. A very noticeable shaking.
I lowered and raise a few times and eventually it goes away. Hydraulic fluids seem to be at full on the dip stick. Any ideas what causes this?
/ 3pt hitch buming/shaking #2
Check the hydraulic pressure, sounds like it's too high.
/ 3pt hitch buming/shaking #4
I've had this happen a couple of times on my CK30. You need to adjust the MLS control valve (control sensitivity adjustment). If that doesn't solve it, unfortunately you'll have to replace it (sticker shock) as you can't rebuild them.
2020 Bobcat E55 (A64126)
2020 Bobcat E55...
3147 (A63117)
3147 (A63117)
New/Unused Quick Attach Pallet Forks (A65583)
New/Unused Quick...
300 Gal Fuel Tank (A64127)
300 Gal Fuel Tank...
Kubota SVL95-2S (A64126)
Kubota SVL95-2S...
QA Pallet Forks (A64127)
QA Pallet Forks...
