3pt hitch buming/shaking
/ 3pt hitch buming/shaking #1
lakngulf
Lake Martin Alabama
Kioti CK30
I have a Kioti CK30. At times I raise whatever implement is attached to the 3pt hitch, and it starts bumping.....bump bump bump. A very noticeable shaking.
I lowered and raise a few times and eventually it goes away. Hydraulic fluids seem to be at full on the dip stick. Any ideas what causes this?
/ 3pt hitch buming/shaking #2
Check the hydraulic pressure, sounds like it's too high.
/ 3pt hitch buming/shaking #4
I've had this happen a couple of times on my CK30. You need to adjust the MLS control valve (control sensitivity adjustment). If that doesn't solve it, unfortunately you'll have to replace it (sticker shock) as you can't rebuild them.
2008 FOREST RIVER CARDINAL 30RK 5TH WHEEL (A65643)
2008 FOREST RIVER...
2018 Bobcat T590 (A64126)
2018 Bobcat T590...
CASE 580N BACKHOE (A65053)
CASE 580N BACKHOE...
2022 John Deere 5055E (A60462)
2022 John Deere...
John Deere 4020 Loader Tractor (A66285)
John Deere 4020...
2018 CATERPILLAR 573D FELLER BUNCHER (A62129)
2018 CATERPILLAR...
