3pt hitch buming/shaking
   / 3pt hitch buming/shaking #1
lakngulf
Lake Martin Alabama
Kioti CK30
I have a Kioti CK30. At times I raise whatever implement is attached to the 3pt hitch, and it starts bumping.....bump bump bump. A very noticeable shaking.
I lowered and raise a few times and eventually it goes away. Hydraulic fluids seem to be at full on the dip stick. Any ideas what causes this?
   / 3pt hitch buming/shaking #2
Check the hydraulic pressure, sounds like it's too high.
   / 3pt hitch buming/shaking #4
I've had this happen a couple of times on my CK30. You need to adjust the MLS control valve (control sensitivity adjustment). If that doesn't solve it, unfortunately you'll have to replace it (sticker shock) as you can't rebuild them.
2017 Ford F-550 Enclosed Service Truck (A53422)
2017 Ford F-550...
2007 Yamaha Rhino 660 (A55315)
2007 Yamaha Rhino...
22ft Rollback Flatbed Body with Winch (A54814)
22ft Rollback...
2013 John Deere 824K Wheel Loader (A57024)
2013 John Deere...
black Max power washer (A53421)
black Max power...
2007 Ford F-150 Ext. Cab Pickup Truck (A55852)
2007 Ford F-150...
