3pt Carry All
/ 3pt Carry All #1
Waynebob126
Pearl, MS
LS XG3037
Got my 3pt carry all finished today. Still need to add some storage type attachments but using it as is already.
/ 3pt Carry All #4
Very nice. :thumbsup: You will find it very handy for all kinds of stuff.
gg
/ 3pt Carry All #5
Turned out nice.
I've noticed a few others that cut the sides at an angle instead of running flush vertically.
Is there a reason that I'm missing. It seems like you could haul more if the side boards were all extended flush.
/ 3pt Carry All
Turned out nice.
I hope the angle will make it easier to reach over the sides
/ 3pt Carry All #9
Nice. Wish I'd thought of that. Needed mine fully enclosed to haul mulch down to the big garden that I no longer use.
Could take yours, add hinges at the outer bottom, with pins in them, and a matching 2nd part to enclose it. Just put latches to hold the 2 parts together. Remove hinge pins to get what you have.
Ralph
/ 3pt Carry All
I owe MMfrompa for the design. Got the dims from his YouTube channel. I have decided that there are 100’s of ways to customize these things
/ 3pt Carry All #11
Very nice.
I made my own and just copied a picture I saw on TSC web site.
What thickness did you use for steel?
/ 3pt Carry All #12
I built mine with no sides at all. Makes it easy to carry long stuff. I mounted hooks on the front of the headboard and under the rear deck and keep a length of small nylon rope which works great for tying down loads of firewood, which I stack crosswise in two or three rows. Hooks visible front and rear here:
/ 3pt Carry All
Very nice.
I bought the Countyline carry all from TSC. Added PT lumber on it and painted to match LS tractor
/ 3pt Carry All #14
Just did mine this last week. Still haven’t decided on how I am gonna do my sides. IMG_1266.JPG
/ 3pt Carry All #15
Ahh okay. Do you have a guess what they used?
I made mine from 5/16 3x3 angle iron with 5/8th thick mounting points.
/ 3pt Carry All #18
Looking great.
After MMM is Carry All probably the most used implement for me.
/ 3pt Carry All #19
Another useful possibility is removable stake sides
gg
/ 3pt Carry All #20
Thanks for you post - got me thinking.
I'm going to have to give some thought to making one of these and the way I handle my work. I have a 4n1 bucket that is on my tractor maybe 20% of the time and it is quite heavy. Most of the time I keep my forks on for toting things around often up to the maximum lift capacity of the FEL. I keep my backhoe on almost all the time, mostly for ballast but I also often find a handy use for it and it's thumb from time to time so it is not just dead weight.
I really like the idea of being able to carry stuff though and lift from the rear as well - I could incorporate ballast into the box as well (BTW my tires are loaded but they get really light with the 4n1 on and the BH off).
6 Band Wooden Barrel (A61574)
6 Band Wooden...
1985 Ford Ltl9000 Tender Truck (A63688)
1985 Ford Ltl9000...
2014 Massey Ferguson 8650 Tractor (A63111)
2014 Massey...
2014 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A61307)
2014 Doyle Dry...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC-55 55ft Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
Toro Greenspro 1260 Towable Greens Roller (A56859)
Toro Greenspro...
