3PT Ballast
/ 3PT Ballast #1
Rowski
North Central Vermont, Jay Peak Area
2004 New Holland TN70DA with 32LC loader, 2000 New Holland 2120 with Curtis cab, 7309 loader
This is a simple ballast. Keeps the weight tight to the tractor. Just a 55 gallon drum with top cut off. Put a draw bar through the lower part of the drum. Attached a piece of square stock with one side partially cut out, to slide the toplink in. I had to bend the drum near the rim to keep the toplink from hitting it when fully raised. Then had it filled with concrete.
Cost
$20 for draw bar
1 hr of my time for using torches and welder
concrete was free!
Estimated weight 1200 lbs.
It will get painted in the summer.
A smaller version could be made with a smaller drum (I think 35 gallon is the next size smaller).
Derek
/ 3PT Ballast #3
Derek,
Also looks like a good bumper in case you back into anything....but than again if you did back into something...ouch..$$
Hope your NH isn't still cover w/ snow and sleeping.
Wow...to snap a plow chain I guess that person hit pretty hard...guess its about time to put up the Frost Heaves signs. /w3tcompact/icons/frown.gif
Thomas..NH /w3tcompact/icons/wink.gif
/ 3PT Ballast
The 2120 loader is being modified with a plow to wing back side snow banks. Also getting a set of chains for the rear. No signs out yet but I agree they need to be out!
Derek
/ 3PT Ballast #5
i do need something like this, and i do have an old drum around, need to get an extra draw bar and some angle iron for the top link attachment, i would need about 600 lbs, how much concrete is that about 7 bags?
alex
/ 3PT Ballast #6
Alex, 600 lbs is approximately 4 cu ft of concrete, but why pay for concrete to put in a drum. Use dirt! You might want enough concrete to reinforce the drawbar if it penetrates the drum.
Quick Attach Backing Plate (A65579)
Quick Attach...
Lonestar Panel (4) 24ft. Free Standing Panels (A65640)
Lonestar Panel (4)...
2009 VOLVO VHD BOBTAIL VACUUM TRUCK (A63569)
2009 VOLVO VHD...
2010 ALTEC DIGGER DERRICK (A59914)
2010 ALTEC DIGGER...
Skid Steer Smooth Drum Roller (A65640)
Skid Steer Smooth...
Galvanized Metal Roof Vents (A64194)
Galvanized Metal...
