3940 lift issue
/ 3940 lift issue #1
beggar
Bronze Member
picayune,ms.
farmtra555-case1494-kubota M4050-F4610-MF285
I got a buddy with a 3940 about 10 or 12 years old and it started with the lift not going down without weight on it. with a disc on it ,it will go down to the ground but with
nothing on it won't go down. He has move the response slow and fast lever back and forth without change. Has anybody had this problem.
/ 3940 lift issue #2
The 3 point hitch? Is there a valve mounted behind the his leg calf area that controls it?
/ 3940 lift issue
yes, on the 3 pt. hitch. I have to check on the valve. I guess you talking about the response valve. I told him to keep working it back and forth I have had trouble with mine on a couple of different tractors.
DAYTON 110,000 BTU OIL FIRED HEATER (A64276)
DAYTON 110,000 BTU...
2014 HAMM HD+140I DOUBLE DRUM ROLLER (A65056)
2014 HAMM HD+140I...
2011 DRAGON  4 AXLE CRUDE TRAILER (A67714)
2011 DRAGON 4...
2014 MAC FLAMELESS HEATER TRAILER (A67714)
2014 MAC FLAMELESS...
1457 (A65054)
1457 (A65054)
Gravely Pro-Turn 148 50in Zero Turn Commercial Mower (A66734)
Gravely Pro-Turn...
