373 three point leaks down
/ 373 three point leaks down #1
bmd365
When I raise the three point hitch it slowys sags down with the engine running. this is only when it has heavy impliment on it. I figure this must be the valve or seals?
Bill D.
/ 373 three point leaks down #2
Most likely the o-rings on the hyfralic piston in the hydrolic control assembly needs to be replaced. While you have the assembly off check the lift yoke for weare where the rod from the piston is attached. Too much where can cause the rod to fall into the trans housing. I am now very fast at remiving and instaling the hydrolic control assembly on my 373.
do you mean the control valve or the cylinder that does the work?
Bill D.
/ 373 three point leaks down #4
Take the assembly under the seat off . this will include the lift arms and the lift leaver. The cylinder head is held on with 4 bolts and will need some work to pull it out. go to www.satohparts.com and look at the diagrams of the hudrolic control unit. It is very unlikely that the valve is the problem the pistion o rings are almost always the culprit. If the cylinder is damaged you need to take it to a hudrolic shop to see it it can be repaired.
2014 REITNOUER ALUMINUM FLATBED TRAILER (A59910)
2014 REITNOUER...
KL480 Ventrac tiller
2006 Cadillac GM Superior Coach 6-Door Limousine - Only 21,567 Miles (A63118)
2006 Cadillac GM...
2013 Komatsu WA320 Wheel Loader (A60352)
2013 Komatsu WA320...
2023 John Deere Z950R Zero Turn (A63116)
2023 John Deere...
2018 VERMEER BC1000 XL PORTABLE WOOD CHIPPER (A63276)
2018 VERMEER...
