3720 - RRC size
/ 3720 - RRC size #1
9973720wb19
Platinum Member
East Coast
Many
I have a fairly new (1yr old) 3720. How wide of a Rough Rotary Cutter can I put on it?
/ 3720 - RRC size #2
Let's see if I can answer first! ... They say you need 5 PTO HP per foot of rotary cutter. Give or take, maybe a little less HP per foot if you're cutting lighter stuff.
/ 3720 - RRC size #3
I run a 60 inch woods on my 3720. I am confident I could run a 72 inch, with the loader on for front weight. They get real heavy back there though. We had a 72 inch Woods on a Farmall 560. This is a fairly good size tractor, not a compact utility, and it made the 560 wheelie all over the place.
/ 3720 - RRC size
thanks guys...I guess I should have mentioned. I'm currently running a Frontier 60in with no problems. And seeking to go larger...72 and if I can an 84?? I never thought about the weight but it would seem to be a factor especially up and down hills.
/ 3720 - RRC size #5
Looks like you have 35 PTO HP, so using the ol' formula, the PTO should operate a 7-footer fine.
You should look at the specs of a single-shaft 7-footer, though, as they get HUGE & HEAVY. If you're talking a double-shaft, it should work great.
/ 3720 - RRC size #7
I suspect he means side by side (two cutters).
/ 3720 - RRC size #8
I have a 96" woods DS96 pull type rotary mower. My 3720 cab has enough power to run it even when the air is on and pulling some pretty steep hills. I do understand that pull types are not great for everything. My dealer did say that the JD and the Woods 3pt 8' rotary mowers would be to heavy for my 3720.
/ 3720 - RRC size #9
Double Shaft? What's that?
1947 Chevrolet Panel (A62613)
1947 Chevrolet...
2023 BOBCAT T66 R-SERIES SKID STEER (A64279)
2023 BOBCAT T66...
Caterpillar D4H Series 1, 2, and 3 Dozer Service, Parts and Operation Manuals (A63117)
Caterpillar D4H...
UNUSED WOLVERINE HYD TRENCHER (A64281)
UNUSED WOLVERINE...
2019 Cadillac XTS Stretch Limousine for Sale, S and S Coachbuilders, 70IN, 7731 Miles (A63688)
2019 Cadillac XTS...
Kubota L4802 DT LA766 Backhoe (A63688)
Kubota L4802 DT...
