3720 - RRC size
/ 3720 - RRC size #1
9973720wb19
East Coast
Many
I have a fairly new (1yr old) 3720. How wide of a Rough Rotary Cutter can I put on it?
/ 3720 - RRC size #2
Let's see if I can answer first! ... They say you need 5 PTO HP per foot of rotary cutter. Give or take, maybe a little less HP per foot if you're cutting lighter stuff.
/ 3720 - RRC size #3
I run a 60 inch woods on my 3720. I am confident I could run a 72 inch, with the loader on for front weight. They get real heavy back there though. We had a 72 inch Woods on a Farmall 560. This is a fairly good size tractor, not a compact utility, and it made the 560 wheelie all over the place.
/ 3720 - RRC size
thanks guys...I guess I should have mentioned. I'm currently running a Frontier 60in with no problems. And seeking to go larger...72 and if I can an 84?? I never thought about the weight but it would seem to be a factor especially up and down hills.
/ 3720 - RRC size #5
Looks like you have 35 PTO HP, so using the ol' formula, the PTO should operate a 7-footer fine.
You should look at the specs of a single-shaft 7-footer, though, as they get HUGE & HEAVY. If you're talking a double-shaft, it should work great.
/ 3720 - RRC size #7
I suspect he means side by side (two cutters).
/ 3720 - RRC size #8
I have a 96" woods DS96 pull type rotary mower. My 3720 cab has enough power to run it even when the air is on and pulling some pretty steep hills. I do understand that pull types are not great for everything. My dealer did say that the JD and the Woods 3pt 8' rotary mowers would be to heavy for my 3720.
/ 3720 - RRC size #9
Double Shaft? What's that?
Case 580 Super E Backhoe Loader (A66285)
Case 580 Super E...
JOHN DEERE 8' OFFSET DISC HARROW (A64276)
JOHN DEERE 8'...
2014 John Deere 310SK 4x4 Extendahoe Loader Backhoe (A61572)
2014 John Deere...
2009 Caterpillar 345D Hydraulic Excavator (A61572)
2009 Caterpillar...
2025 Swict 66in. Bucket Skid Steer Attachment (A61572)
2025 Swict 66in...
2021 Redirective Crash Cushion Guardrail (A61573)
2021 Redirective...
