3720 prices
/ 3720 prices
Go with the R1 tires and wheels. That way you can turn the wheels out to a wider postion to give you the stability you want and need. With the R4 tires and wheels you can't get as wide. I have R4's on my 3520 cab and no way could I ever get around my place with the R4 rear wheel stance. I ended up adding unverferth 4 inch extensions giving me another 8 inches width in the rear. It makes a difference but, I still can't take the 3520 in places I took my old JD870.
The cruise control is an easy install yourself. Just follow the instructions and you can do one is less than an hour.
I certainly don't want to start another tire war but I have R1's on my 790 and I get great traction on dirt and in snow. Wouldn't think of anything else. I actually thought the R4 would be more stable since they are lower and wider. Hadn't realized that the R1 wheels could be put wider. Thanks.
/ 3720 prices #22
You might want your dealer to install the cruise control because I think the computer has to be reprogrammed for it.
I had looked into it...From what I gather the instructions on how to program come with the "Enhanced" Cruise Kit and its fairly easy to do.
/ 3720 prices #23
I'm not talking tires, I'm talking the rear wheel stance. You just can't get enough rear wheel width with the R4 wheels unless you go with some sort of wheel extension. The R1 wheels have the ability to adjust to several different widths. So, the R1 wheels are the way to go if you need extra stability.
Below pics: 3520 with R4 wheels and tires.
Before I added 8 inches to the rear wheel stance.
After I added 8 inches to the rear wheel stance.
There is NO WAY! I could have used the 3520 on my place with the factory wheel width.
Sincerely, Dirt
/ 3720 prices
I understand the wheels for the R1 tires adjust wider than the wheels for the R4 tires. Thanks.
/ 3720 prices
I just received the final quote from this Dealer --
3520 with Hydo, rear lights, third valve, tool box, radio kit, 300cx loader, HD bucket, 3rd function hard lines, engine heater, cruise control upgrade ($89), horn, rear wiper, filled tires and me installing everything but the loader -- $30,586.60.
Still only $11,000 for my tractor and loader which he said he can't move on. I just can not justify almost $20,000 difference and even if I could get a dealer to discount 20% instead of what I think is about 14%, and if I sell my tractor myself for more, I don't see how to justify it. My 790 is not worth much more than is left on my zero interest loan and I invested $1000's of dollars in it.
My 790 does everything I have to do well except I get cold on it and I just graded a driveway for a neighbor and I don't think I could have done it with cab because of the trees so I'm going to stay with what I have.
Thanks for everyone's help.
/ 3720 prices #26
I just agreed to buy a new 2007 JD-4520, cab, air seat, 400CXP loader, cruise, radio, ehydro, telescoping draft links, 3rd control valve kit, dual mid SCV, rear work lights, mirrors, auto type cruise control and industrial tires. I'm right at $35K out the door.
Sounds like your dealer is a bit high. Negotiate harder or shop another non-affiliated dealer. Good Luck!
/ 3720 prices #28
God I would think with everybody in an Economic Panic... he would be willing to deal right now.. That is very high....!!! The negotiating prices have come way down since I bought my 3720 Cab tractor... I'm sure I paid way more than if I waited a year... but, when you need something... and they are hard to get.. and I was in a race against winter... I was willing to pay more...
A Realistic price would be about 31~33K.....
And yes... nothing beats the factory cab... it's worth every penny... I've had the other cabs... on other tractors... this cab is perfect...
Jason
/ 3720 prices #29
Sincerely, Dirt
Hello Dirt, I still think once in a while i might want to try Unverferth Hub spacers, buit sofar the Turf Speacials are working very good.
2022 FORD F-250 XL SUPER DUTY CAB & CHASSIS (A67714)
2022 FORD F-250 XL...
2014 FORD F-150 (A67714)
2014 FORD F-150...
1994 WELD-IT COMPANY 130BBL FUEL PUP TRAILER (A67714)
1994 WELD-IT...
THUNDER CREEK FUEL TRAILER (A67714)
THUNDER CREEK FUEL...
CASE SV208 SMOOTH DRM ROLLER (A67714)
CASE SV208 SMOOTH...
2013 VOLVO A40F OFF ROAD DUMP TRUCK (A65056)
2013 VOLVO A40F...
