3700 no start
/ 3700 no start #1
hunter82i
L3700SU
Need some help from TBN. L 3700 will not crank. Battery voltage ok. It seems like a safety is locking out the starter. I've checked the seat safety and pedal safety. Verified pto is off. All fuses seem ok.
What am I missing? What else could be locking out the starter?
/ 3700 no start
Thanks guys. I will check voltage at the starter. I forgot to mention the clutch safety. Does anyone know if these safeties are normally open or normally closed?
/ 3700 no start #5
not sure ..but easy to check with a voltmeter or ohm meter.
/ 3700 no start #6
Happened one time to me - started checking the safety switches and couldn't find any problems. So I was sitting there and tried it again, nothing, rocked the HST pedal a few times while hitting the switch and bingo, it starts. It seems that switch is very picky about the position it is in.... Plus I forgot the HST had a switch on it.
Good luck
/ 3700 no start
Good luck
I will try this as well. The safety for this in under the dash.
/ 3700 no start #8
Check that the PTO engagement lever is fully 'off'. That got me last spring.
JayC
/ 3700 no start #9
Even now, every once and a while mine is picky about starting so I rock it and hit the key and I am back in business. it seems if it is out of position 1/8 of an inch the interlock kicks in and there is no starting the tractor.
/ 3700 no start #10
Is is making any noise like a click? Had that happen to me twice on my L3710. Once it was the pto lever safety. Another time it turned out to be a bad battery. I checked the battery and the starter and had plenty of volts. Spent quite a bit of time testing things, even rebuilt the starter solenoid. Eventually found out it was a bad battery - had plenty of volts, but not enough cranking amps. A battery tester would have saved me a lot of time.
If you don't figure it out, and want wiring diagrams. I have them for the L3710, which is probably similar. I might be able to scan them in. Let me know if you want them and I'll give it a try.
Hope this helps a little :)
/ 3700 no start
Alright guys,
Had time yesterday to dig in more. Meter showed that on key start the starter solenoid was only getting about 9.8 volts. This was weird, if it were a bad key switch I'd expect no volts. So I warmed up the glow plugs, put the key to the on position, and jumped to solenoid to the starter wire to fire it up. Ran it for about an hour and a half to make sure battery was charged.
I reluctantly shut it off only to try and restart again. VOILA! Key start worked fine this time. Can't say that I'm thrilled to have an intermittent electrical issue but it is good to know I can bypass all of the start safeties if I get into a bad situation.
I will follow back up now that the motor has cooled again and see if the problem comes back. Last year I pulled the tractor on a trailer during a snowy day in KY and I'm afraid the road salt is causing issues.
More to come, and thanks for all the ideas.
/ 3700 no start #12
My B7510 died on me one day. I pulled it onto the trailer and hauled to the dealer. The tech diagnosed the electronic block that reads all the signals as bad. He ran a jumper wire from the positive side of the battery down to the fuel shut off solenoid located on the fuel pump. I heard the solenoid click and she started right up.
As stated check all your safety inputs - PTO, clutch depressed, weight in the seat, etc.
New/Unused Quick Attach Pallet Double Hay Spear (A65583)
New/Unused Quick...
KOMATSU FORKLIFT (A63291)
KOMATSU FORKLIFT...
UNUSED IRMC HIGH-END MASSAGE CHAIR (A64281)
UNUSED IRMC...
Yale 5K Forklift (A63688)
Yale 5K Forklift...
2022 New Holland C327 Compact Track Loader (A63689)
2022 New Holland...
Landhonor Quick Attach Tree Puller (A66285)
Landhonor Quick...
