Traction 3510 with broken clutch return spring
   / 3510 with broken clutch return spring #1
tman53
S.E. Michigan
I have had my Branson 3510 for 10 years now and use it regularly around my 11 acres, it has never let me down, ok except for a fuel pump issue that was probably my fault.
Today is my first event. After using the machine for a few minutes I pushed in the clutch felt some slight resistance then heard a "popping" noise and a broken spring fell onto my foot. The machine still works however the clutch reurn is obviuosly different (very slow). Anyone have this happen? How do I get a new spring and where in the heck is it supposed to be? I cannot see where it may have come from. Any help would be appreciated
Simple fix Part number TC73090000A4. $15 spring that should cost no more than 5 bucks.
Informational Lot - Financing (A56438)
Informational Lot...
2020 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59904)
2020 FREIGHTLINER...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A60429)
KNOW BEFORE YOU...
Greenworks Commercial 82V CZ60R Zero-Turn Mower-DEMO UNIT (A56438)
Greenworks...
SULLIVAN PATEK AIR COMPRESSOR (A55745)
SULLIVAN PATEK AIR...
Case 2390 Tractor (A59814)
Case 2390 Tractor...
