3510 With Boxblade
/ 3510 With Boxblade #1
Stimw
Elite Member
N. E. Florida
I've got 21 hours on my 3510 (with R-4 tires) mowing and spreading fresh dirt. Today I decided to remove an old stump about 14 inches accross that I cut down 2 years ago. I have a KingKutter 5' Boxblade that I bought recently. I set the rip teeth 1 notch down and started scraping dirt and roots away. Put it in 4 WD, 2nd range, first gear and proceeded to rip roots right out of the ground. I've driven dozers and loaders before and I am very impressed with how much power this tractor has! This thing IS NOT A TOY! It hung a couple of times and spun the tires, it didn't even try to bog down. I just changed angles and ripped the root right out!
I put pretty good strain on the Boxblade and it took it very well. I also bought a KK 5' finish mower and I'm not too happy with it but the blade is a good buy. The way the Cutting edges are put back to back and made with a curve to them gives it a lot of strength. I pulled dirt and even pushed dirt with it and it did very well.
There are trees all over my property living in fear as I type! tim
/ 3510 With Boxblade #2
Tim, sounds like you are having a good time with the 3510. That bush your wife planted , but you have to mow around all the time, may just accidentally get ripped out. Operator error, right? Welcome to the club.
sassafraspete
/ 3510 With Boxblade #3
I can relate. I have operated cats, excavators and skidders. I'm not gonna say my 3510 will push as much as a cat or skidder but..last night I was pushing 5-7 6 to 8 inch trees over to the edge of my field. I also have been taking down some fairly big trees. The power is more than I expected when I bought the machine.
The amazing thing to me is I still had 4 more gears lower to go to! I don't know what you would use them for.
/ 3510 With Boxblade #5
I was using the lowest gear to push my trees from the root ball after I had pushed them over. I probably would not have had to work so hard if I could have taken all the roots out first, but I don't have the room to manuever with the box blade as my trees are close.
/ 3510 With Boxblade #6
What technique were you using to push the trees over?
Did you use the bucket?
I used the box blade, I rake as much dirt as I can around the tree then back up to the trunk and push/rock it with the box blade. I even come into the stump low as possible and raise the blade lifting the stump to loosen it. It takes a little time but it gets the job done.
Watched a friend clear some trees with a large track hoe last week. He was grabbing oak trees about 20' up and snaping them off at about 12" in diameter then he yanked the stumps right out of the ground. I wasn't there at the time but he got too close to a large pond, the hoe slid and turned over. Nothing like seeing a 50,000lb machine on it's side. At least he wasn't hurt! It took a LARGE wrecker 4 hours to get it back up again. A couple hours latter they had it running too. I have pictures , I just need to resize them to post.
/ 3510 With Boxblade #8
I have a choice of the box blade or the backhoe for ripping up the roots, prior to pushing over some pretty good sized trees. It had not occurred to me that I could use the box blade. Anybody have any experience with which is best?
3820i 6' BB, 8620 BH, FEL
/ 3510 With Boxblade #9
Just keep in mind that the three point arms are stronger pulling then pushing. A Branson is a heavy tractor and can bend the arms if you play bulldozer too agressively.
I would think the backhoe would work better. I don't have the hoe (yet) on mine. You need to loosen the roots to remove the tree. Here in Florida we have a lot of sand so your results may varry.
Will try to post pics of overturned track hoe.
/ 3510 With Boxblade #13
mudcat,
You were able to push those trees over with a 3510? WOW... If I tried that with my 4020 I would only blow hydraulic hoses which I have blown 3 this past summer. Good luck to ya.
Ron
/ 3510 With Boxblade #14
Great pics mudcat....I wish I had that sandy soil to work with rather than this old sticky clay...just wanted to know what you thought of the tough top on your 3510??? been thinking about getting one of them for mine....Brian
/ 3510 With Boxblade #15
RonT, I worked the 3510 pretty darn hard and it seemed to like it /forums/images/graemlins/smirk.gif. I dug around the tree, snapping off as many roots as I could. Then I would push on the tree and look for any spots that roots I may have missed. TIMBER!!!
Sorry to here about your hydraulic troubles, sounds like it just wasn't right to begin with. I really like my Branson. I think it compares to any of the Big Three. I'm not just saying that because I own one. It is the reason why I bought one /forums/images/graemlins/smile.gif.
Good luck to you.
/ 3510 With Boxblade #16
Brian, I really like the top. It isn't a TUFF TOP brand though. It is one that the local Branson dealer carried. I did check out the TUFF TOP and really liked it. Not sure if it would cut out any noise bouncing off of it. The top on my tractor has a layer of insulation that cuts down on a lot of the noise.
2012 Cadillac CTS Sedan (A66738)
2012 Cadillac CTS...
2012 FORD F150 REGULAR CAB PICKUP TRUCK (A66091)
2012 FORD F150...
TAG 48" QUICK ATTACH EXCAVATOR BUCKET (A65053)
TAG 48" QUICK...
12ft T/A Flatbed Utility Trailer (A64553)
12ft T/A Flatbed...
2003 Proclaim Tanker Trailer (A64194)
2003 Proclaim...
2020 INTERNATIONAL MV607 REEFER TRUCK (A67714)
2020 INTERNATIONAL...
