345 starting issues
/ 345 starting issues #1
Insbroker2
John deere 345
My 345 blows a fuse as soon as the key is turned. I've checked for a dead short with no luck. I'm thinking ignition module, but dont want to spend the bucks and be wrong. Any ideas? Thanks.
/ 345 starting issues #2
:welcome:
To check for a short, make up a test bulb with leads that let you plug the light in where the fuse is at. A direct short will cause the bulb to be lit. Then you can search for the short by moving wires and lifting contacts. It saves on a lot of grief and going through fuses.
Getting a service manual with the wiring diagram will be worth it if you are trying to fix this yourself.
/ 345 starting issues #3
Sound like ignition module. My JD 325 was doing some crazy things and I replaced the ignition module and it starts and runs a lot better. I got it off ebay, someone had order the wrong one and it was $50 as he resold it. I believe another seller has them for $77 new, but check and make sure which one you need. It takes bout 30 minutes piddling around to put it on.
Ok, now what? As suggested i used a test light and it worked correctly, so i put in a fuse and. It didnt blow, but now i have a hammering sound when i try to start it. Starter or selenoid maybe?
15k TRIPLEX PUMP (A63569)
15k TRIPLEX PUMP...
iDrive TDS-2010H...
2013 Kubota BX2370 54in 4x4 Compact Utility Tractor Mower with 48in Rotary Brush Cutter (A61572)
2013 Kubota BX2370...
Land Honor 32� Backhoe Excavator Thumb (A64047)
Land Honor 32�...
2021 Kubota M7060D tractor W/ Loader (A64047)
2021 Kubota M7060D...
2021 Cam-Am HD8 (A64047)
2021 Cam-Am HD8...
