345 starting issues
/ 345 starting issues #1
Insbroker2
John deere 345
My 345 blows a fuse as soon as the key is turned. I've checked for a dead short with no luck. I'm thinking ignition module, but dont want to spend the bucks and be wrong. Any ideas? Thanks.
/ 345 starting issues #2
:welcome:
To check for a short, make up a test bulb with leads that let you plug the light in where the fuse is at. A direct short will cause the bulb to be lit. Then you can search for the short by moving wires and lifting contacts. It saves on a lot of grief and going through fuses.
Getting a service manual with the wiring diagram will be worth it if you are trying to fix this yourself.
/ 345 starting issues #3
Sound like ignition module. My JD 325 was doing some crazy things and I replaced the ignition module and it starts and runs a lot better. I got it off ebay, someone had order the wrong one and it was $50 as he resold it. I believe another seller has them for $77 new, but check and make sure which one you need. It takes bout 30 minutes piddling around to put it on.
Ok, now what? As suggested i used a test light and it worked correctly, so i put in a fuse and. It didnt blow, but now i have a hammering sound when i try to start it. Starter or selenoid maybe?
2017 Case CX145D (A60462)
2017 Case CX145D...
John Deere 1418 Bush Hog (A64047)
John Deere 1418...
TPL MECHANICS BODY LUBE SKID (A60429)
TPL MECHANICS BODY...
2022 MACK ANTHEM AN64T 6X4 T/A  SLEEPER TRUCK TRACTOR (A59910)
2022 MACK ANTHEM...
2015 WESTERN STAR 4900 GLIDER TANDEM AXLE DAY CAB (A59575)
2015 WESTERN STAR...
Kubota Skid Steer Pallet Forks (A64047)
Kubota Skid Steer...
