3320 error 08
/ 3320 error 08 #1
tervete
Martintown, ON, Canada
JD 3320
my first tractor, got it last Friday. A used 2009 JD 3320, it has error 08 showing up. How do I fix this?
/ 3320 error 08 #2
I have a PDF of the tech manual you're welcome to, just shoot me your email
Joe
your #08 error -
Err 08 Throttle Sensor Voltage signal out-of
range or not calibrated.
No anti-stall function;
Loss of performance.
Calibrate the sensor. Check the
sensor and 499 Wht wire and
connections.
/ 3320 error 08 #3
From the owner manual:
"Err 08
Throttle Sensor.
Voltage signal out-of-range or not calibrated.
No anti-stall function; Loss of performance.
Contact your John Deere dealer.
//greg//
/ 3320 error 08
I got the tech manual (tx Joe) and it was easy to fix. Getting in the diagnostic mode was easy and adjusting the throttle sensor was also easy.
Tx.
Pauly
/ 3320 error 08 #6
Joe
your #08 error -
connections.
Same issues as tervete. Have yet to find a guide to the solution via the internet.
I was contemplating the $340 on the JD tech manual but was reluctant to do so if the fix was beyond my capabilities. So worst case, 340 + JD service fee was not what I would call a win.
Would you be willing to share the .pdf as you offered tervete?
08 challenged.....
/ 3320 error 08 #7
Check your messages
Unused 2023 Kubota AP-SSG2024 24in. Hydraulic Stump Grinder Skid Steer Attachment (A66734)
Unused 2023 Kubota...
BOAT MOTOR (A66738)
BOAT MOTOR (A66738)
2020 KENWORTH T880 (A67714)
2020 KENWORTH T880...
2016 Autocar ACX Xpeditor T/A New Way 31ASL 31Yd. Side Loader Garbage Truck (A66736)
2016 Autocar ACX...
1979 MERIT FUEL TRANSPORT TRAILER (A67714)
1979 MERIT FUEL...
Delta BS100 Shopmaster Bandsaw (A64553)
Delta BS100...
