3320 error 08
/ 3320 error 08 #1
tervete
Member
Martintown, ON, Canada
JD 3320
my first tractor, got it last Friday. A used 2009 JD 3320, it has error 08 showing up. How do I fix this?
/ 3320 error 08 #2
I have a PDF of the tech manual you're welcome to, just shoot me your email
Joe
your #08 error -
Err 08 Throttle Sensor Voltage signal out-of
range or not calibrated.
No anti-stall function;
Loss of performance.
Calibrate the sensor. Check the
sensor and 499 Wht wire and
connections.
/ 3320 error 08 #3
From the owner manual:
"Err 08
Throttle Sensor.
Voltage signal out-of-range or not calibrated.
No anti-stall function; Loss of performance.
Contact your John Deere dealer.
//greg//
/ 3320 error 08
I got the tech manual (tx Joe) and it was easy to fix. Getting in the diagnostic mode was easy and adjusting the throttle sensor was also easy.
Tx.
Pauly
/ 3320 error 08 #6
Joe
your #08 error -
connections.
Same issues as tervete. Have yet to find a guide to the solution via the internet.
I was contemplating the $340 on the JD tech manual but was reluctant to do so if the fix was beyond my capabilities. So worst case, 340 + JD service fee was not what I would call a win.
Would you be willing to share the .pdf as you offered tervete?
08 challenged.....
/ 3320 error 08 #7
Check your messages
2014 Takeuchi TB260 Midi Excavator (A64553)
2014 Takeuchi...
72in. Fork Extension (A64553)
72in. Fork...
2006 KOMATSU FD80T-8 FORKLIFT (A67148)
2006 KOMATSU...
2008 Toyota Camry Sedan (A64557)
2008 Toyota Camry...
2012 Honda Civic Sedan (A64557)
2012 Honda Civic...
2013 FREIGHTLINER M2 4X2 26FT NON CDL BOX TRUCK (A67148)
2013 FREIGHTLINER...
