3110D - GPM?
/ 3110D - GPM? #1
Republic of Texas
North East Texas
John Deere 850 - Yanmar 3110D
How many GPM does thw hydraulic pump put out on the 3110D?
I'm looking to add remotes & so I need to know which control valves to buy.
/ 3110D - GPM? #2
Hoye sells this pump for your tractor without power steering. Do you have power steering? I believe it is rated at 9cc. HYDRAULIC PUMP: Yanmar Tractor Parts I believe that translates to 5.7gpm at 2400rpm. Not sure whether your original pump puts out that much or not . I suspect it has a tag on it showing the cc's. Might take a look.
/ 3110D - GPM?
If I were to add more remotes & control valves, do the control valves have to be rated for 5.4 GPM?
Or, can I use a valve that is rated for higher GPM?
/ 3110D - GPM? #4
You can use one rated for higher. (8GPM I believe)I added a grapple valve. it works just fine. I think it's just saying it won't handle anymore than 8 GPM
/ 3110D - GPM? #7
If you click on Kenmac's name and then on his threads you can likely find them.
/ 3110D - GPM? #10
If I figured it out, anyone can. What loader do you have ? Does the loader valve have a PB port. You would have to be able to get a PB sleeve for the loader valve.
/ 3110D - GPM?
My loader is made by some unknown company, Apple Implement Mfg. I can attach pics if needed.
Yes, my valve has a PB port that is currently plugged.
/ 3110D - GPM? #12
You will need to know the valve manufacture in order to get a PB sleeve. We have seen several loader brands here, I don't recall ever seeing one labeled as Apple. If they have a ph # they may be able to help with a PB sleeve
/ 3110D - GPM?
A Google search for the brand name revealed absolutely 0 hits. Weird.
I'll try to get the valve manufacturer this weekend.
/ 3110D - GPM? #16
Just curious, you never responded whether you have power steering. Also curious, does the 3110 have a kill cable or do you just close the throttle? Hopefully the loader valve will have a tag on it.
/ 3110D - GPM?
No power steering. No kill cable. Simply close the throttle to kill it.
/ 3110D - GPM? #18
bet that thing is a bear to steer with a bucket full. I don't know what I would do without PS .. LOL
/ 3110D - GPM? #19
I was doing a similar thing last weekend moving old power pole cuts and tree's to the burn pile. The rear end was bobbing up and down it was that heavy and I found it very difficult to steer. I'd probably break something if I had PS on mine. One of these days I will have to get me a tractor more sized to what I do or i'm going to break this poor 1500 in half (which I am surprised hasn't happened yet!) :shocked:
/ 3110D - GPM? #20
The rears are full of water, and there is a weighted box blade on the rear to keep it down :D
2006 Heil DOT 406 Comp Fuel Tanker (A64194)
2006 Heil DOT 406...
2007 HEIL TRAILER (A67714)
2007 HEIL TRAILER...
2009 FORD CROWN VICTORIA (A66091)
2009 FORD CROWN...
2007 (INOPERABLE) INTERNATIONAL 9900I (A67714)
2007 (INOPERABLE)...
2016 Nissan Frontier Crew Cab Pickup Truck (A66736)
2016 Nissan...
CAT D5 Rear Screen (A68134)
CAT D5 Rear Screen...
