3020 Diesel will not statt
   / 3020 Diesel will not statt
Does the starter turn over the engine. If it does not check the starter to make sure it is all okay. If it is don’t try and start the engine. Remove all the injectors and then roll over to expel any fluid. Then figure where the fluid is coming from and fix that.
If there is fluid lock and the engine starts it can cause serious damage.
It does try to turn the engine over....but it’s almost like it don’t have the power! I put new batteries and heavy duty cables on it and it does the same thing. I’m pretty sure that there’s fuel in the oil again because the oil is REALLY thin and I use ROTEX oil! I’m like you though...it may be starter is just too weak to turn that engine over. Gonna do more troubleshooting on it today
Carlton OX Walk-Behind Tracked Stump Grinder (A55851)
Carlton OX...
2015 Land Rover Evoque SUV (A53424)
2015 Land Rover...
FAE UML/SSL 150 VT QUICK ATTACH HYD MULCHING HEAD (A51406)
FAE UML/SSL 150 VT...
2019 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A51246)
2019 CATERPILLAR...
TANK MANIFOLD (A55745)
2022 FREIGHTLINER CASCADIA SLEEPER (A56129)
2022 FREIGHTLINER...
