3015 speed lock doesnt work
/ 3015 speed lock doesnt work #1
Byra
North central Florida (Alachua)
Mahindra 3015
The speed lock (cruise control) on my 3015 isnt working correctly. When I try to lock it at some given speed, it slips and within about 10 seconds its back in neutral. I didnt see anything in the manual about adjustment, but Im assuming that something just needs tightening. Has anyone else dealt with this?
Thanks!
/ 3015 speed lock doesnt work #3
Byra, I have never tryed to use my lock. Further, I have never looked at the methode use to lock it down. I would guess it is a friction lock and only needs a nut tightened to increase friction. I will try to look at mine tonight and report back.
/ 3015 speed lock doesnt work #4
I would check with your dealer, there is an adjustment procedure for the tension on the lock. Your dealer should be able to do it.
/ 3015 speed lock doesnt work #5
Byra,
My 2615 seems to do the same thing when in high or medium and using the brakes(L & R individually). So far it appears to be fine in low.
I'd like to know what you find out!
2018 INTERNATIONAL LT625 DAY CAB W/ WETLINE (A62613)
2018 INTERNATIONAL...
F-250 Super Duty 4WD 6.2 (A63688)
F-250 Super Duty...
Case SV280B (A60462)
2024 Better Built 7'x12' Trailer (A64127)
2024 Better Built...
Hobart Champion 16 AC/DC Engine-driven Welder and generator (A63689)
Hobart Champion 16...
LERN REMCOR ICE DISPENSER, MICROWAVE (A64276)
LERN REMCOR ICE...
