3 rd function for L3240
/ 3 rd function for L3240 #1
Obejuan64
Central, nj
Kubota L3240
I helped a friend of my install rear remotes on a L3400, 3 rd function was very easy, rear remotes required a little fabricating due to 3 rd party parts, I want to do the same with my L3240 with oem parts rear remote seem like a simple job, but a 3 rd function looks like more werk on a L3240 the PB is all steel tubing from the tranny to the quick connect, anyone know the details for installation or where I can down a PDF?
479.0 KB
/ 3 rd function for L3240 #2
Take a look in the hydraulics sub-forum and run a search there. There are many ways to skin this cat, and the question is what are your needs and what would you like to do? I've done it with a diverter on the loader controls on 2 tractors. Some use the rear remotes for the 3rd function. Others use a true 3rd function where there is an electric valve actuating another circuit that is independent of the main loader controls (the Kubota OEM method). Lots of ways to do this - all depends on your skills, and what you want.
/ 3 rd function for L3240 #3
I have a PDF file of the factory Kubota L2221 installation instructions but I do not see a way to attach it here. If you PM an email address to me I can send it to you.
/ 3 rd function for L3240 #4
I think I have it for the L4240.I remember you have to pull the rear wheel....not an easy task by itself.
/ 3 rd function for L3240 #5
I have a 5740 with the Kubota OEM 3rd function. Before that I had a 5030 with the W.R. Long 3rd function.
With that experience in view, I would have opted for the Long system over the OEM. The Long product was perfect out of the box. The OEM was problematic and required a lot of adjustment, and the carbuncle box sitting outboard and beneath the starboard door is ripe for damage.
/ 3 rd function for L3240 #6
You could cut a section out of the tubing and use compression fittings to install the 3ed function valve.
You don't have to pay $600 to $800 for a 3ed function kit.
I got a installation PDF for the PB 3 rd function n I'm not crazy about having to drain my hydraulic oil that I just rescently changed n replacing steel tubing, so I'm going with a diverter 3rd function, moving all 3 functions at one time is not as important, I rather be able to feather the 3rd function, will do the rear remotes with kubota oem, thanks for the help.
2009 Case CX240B Excavator (A64194)
2009 Case CX240B...
2018 Western Star 4900 Tandem Dump (A62613)
2018 Western Star...
STORAGE FEES (A59914)
24 Gauge R Panels (A65640)
24 Gauge R Panels...
2022 EZ-GO ELITE...
2016 Ford F-650 18ft Hydraulic Dovetail Hauler Truck (A61573)
2016 Ford F-650...
