3 pt quick attach for skid steer attachments
/ 3 pt quick attach for skid steer attachments #1
lars
As all the attachments for my NH 52LC loader are skid steer quick attach, I thought it would be nice to have the ability to hook them up to the 3 point also. The only attachment I found was at preseeder.com and it was for a cat 1, and mine is a cat 2 three point. I thought that if I went back into the woods it would be nice to have the bucket on the front and haul a gear box on the forks mounted to the rear.
Anyone know of a quick tach that mounts to the 3 point that is cat 2 and can handle skid steer type attachments??
Thanks - Dan
/ 3 pt quick attach for skid steer attachments #2
I am not sure how that would work ...I would have trouble engaging my quik-tach implements without "curl". If you just want to haul stuff, what about a pallet mover for your 3ph? build whatever structure you like with a pallet base.
I have a roadrunner grader for my 3ph, and I know that they make one with quick-tach on the "other end" so you can use it either way ...depending on the attachment, you could use the same trick ...
New/Unused Landhonor 60 Gallon Sand Blasting Cabinet (A65583)
New/Unused...
39' 9" 3-Bar Drag Tooth Harrow (A66285)
39' 9" 3-Bar Drag...
Farm King 300-bushel Gravity Wagon (A66408)
Farm King...
Buckhorn Poly Bulk Seed Box (A66408)
Buckhorn Poly Bulk...
2019 TAKEUCHI TL12V2 SKID STEER (A65053)
2019 TAKEUCHI...
New/Unused Landhonor Quick Attach Pallet Forks (A65583)
New/Unused...
