3 pt quick attach for skid steer attachments
/ 3 pt quick attach for skid steer attachments #1
lars
As all the attachments for my NH 52LC loader are skid steer quick attach, I thought it would be nice to have the ability to hook them up to the 3 point also. The only attachment I found was at preseeder.com and it was for a cat 1, and mine is a cat 2 three point. I thought that if I went back into the woods it would be nice to have the bucket on the front and haul a gear box on the forks mounted to the rear.
Anyone know of a quick tach that mounts to the 3 point that is cat 2 and can handle skid steer type attachments??
Thanks - Dan
/ 3 pt quick attach for skid steer attachments #2
I am not sure how that would work ...I would have trouble engaging my quik-tach implements without "curl". If you just want to haul stuff, what about a pallet mover for your 3ph? build whatever structure you like with a pallet base.
I have a roadrunner grader for my 3ph, and I know that they make one with quick-tach on the "other end" so you can use it either way ...depending on the attachment, you could use the same trick ...
JOST FIFTH WHEEL PLATE (A64276)
JOST FIFTH WHEEL...
2023 Globe Trailer GTDD30236 36ft. 75yd. T/A End Dump Trailer (A61573)
2023 Globe Trailer...
2016 CATERPILLAR D6K2 LGP CRAWLER DOZER (A65053)
2016 CATERPILLAR...
2015 Chevrolet Impala Sedan (A64557)
2015 Chevrolet...
2012 CLUBCAR GAS GOLF CART (A65054)
2012 CLUBCAR GAS...
2004 Caterpillar 315CL Excavator (A64194)
2004 Caterpillar...
