3 PT. HITCH NOT RAISING
   / 3 PT. HITCH NOT RAISING #1
Anonymous Poster
Epic Contributor
My 3 pt. hitch is only raisng up about 2 inches, and is slow tractor only has 20 hours on it, the FEL works fine. i know there is an adjustment knob under the seat for the 3 pt. but before i turn it i wanted some input, tractor is still under warrenty so i could take it to dealer if this is a major problem. thought maybe there was a simple slution. please respond if you got the answer.
   / 3 PT. HITCH NOT RAISING #2
Yeah I would consider the 3pt raising only 2 inches a problem. You know there is an adjusement knob under the seat, so turn it. What does your owners manual say. On my tractor the adjustment is for speed of drop and if it closed and you try to raise the 3pt you will ruin it. I suggest turning the knob CCW a couple spin and gently see if your hitch responds better.
   / 3 PT. HITCH NOT RAISING #3
THE KNOB UNDER THE SEAT IS ONLY FOR LIFT ARM DROP
IT COULD BE A NUMBER OF THINGS
IF YOU HAVE A LOADER IT A VALVE NEED TO BE TURN
CALL AND CHECK WITH DEALER OR GIVE ME A CALL
540 894 8770
THANKS TO THOSE WHO REPLIED, ALL IT WAS AND THIS IS EMBARRASING IS THE PIN HAD COME OUT ON ONE OF THE ARMS. ALL SET, PLOWED WITH IT TODAY BUT THANKS FOR ANSWERING
SKYJACK SJIII 3219 SCISSOR LIFT (A60429)
SKYJACK SJIII 3219...
2012 UNVERFERTH 13-INCH REAR SPACERS FOR 10 BOLT HUB (A55315)
2012 UNVERFERTH...
HIGH END MINI GOLF CART (A58214)
HIGH END MINI GOLF...
2012 Ford F-250 Pickup Truck (A59230)
2012 Ford F-250...
2013 PETERBILT 389 (INOPERABLE) (A58214)
2013 PETERBILT 389...
2009 Kubota RTV1140 (A57149)
2009 Kubota...
