3 point
/ 3 point #1
darrenjttu
Glen Rose, Tx
JD 4300
My 3 point is slowly falling to the ground on my JD 4300. If I lift the lever up it goes back up and then the cycle continues. Takes about 1 minute to fall all the way down. The fluids are fine and I have no leaks. Any thoughts?
/ 3 point #2
Did it just start doing this suddenly??
Or has it gotten worse over time??
/ 3 point #3
Have you tried closing the drop rate valve some?
/ 3 point
It has been steady for a while. I didn't think to adjust the drop rate. I guess I need to find out where that is.
/ 3 point #6
Quote: If I lift the lever up it goes back up and then the cycle continues.
Are you saying the lever is falling down?
/ 3 point
The lever falls down a little bit then stops. The three point will fall all the way down if I don't hold the lever all the way up
/ 3 point #8
The Drop Rate valve only sets the speed of drop when the lift lever is activated toward the lower position. I took your first post to indicate the 3pt drops without moving the 3pt lever to the "lower" position. If I misunderstood I'm sorry.
If this is a steadily worse problem it's likely your 3pt lift cylinder leaking. It is located inside the trans/rear axle housing, under the seat. Reguires a pretty serious teardown to access it. Rebuilding the cylinder itself is very easy.
Not sure how mechanical you are?? So can't offer a suggestion as to whether to try it yourself or hire it done. The parts are cheap. The labor will be a bit pricey.
/ 3 point #9
As to post #7.
Does your tractor have position control 3pt???
If so, and the lever falls down on it's own to cause the 3pt drift, forget everything I've said to this point...... :)
I guess I'll step out and wait for more information and clarity. Sorry for the confusion. :)
2019 F-550 Bucket Truck (A63689)
2019 F-550 Bucket...
20ft trailer (A61569)
New/Unused Wolverine Quick Attach Auger (A65583)
New/Unused...
PACER 2" PUMP, BRIGGS & STRATTON ENGINE, HOSE (A64276)
PACER 2" PUMP...
Hayrack Wagon (A66408)
2018 PETERBILT 567 (A65643)
2018 PETERBILT 567...
