3 point top link draft assembly
/ 3 point top link draft assembly #1
7mmTCU
MF 3165
Anyone know if a spanner is available for the nut that holds the top link plunger and spring in? I saw one post that advised to take out the set screw (which I did) and use a punch to work it around. Hate to say it, but this one is going to take more than a punch to break it loose!
D
/ 3 point top link draft assembly #2
Hi -
The upper link adjustment nut on your tractor looks very similar to the one on my MF 302. For the 302, the spanner wrench needs to be 2 inches, center to center, with 1/4 inch diameter pins. Before you buy a 2 inch spanner, measure your tractor nut with a ruler to verify that yours is in fact 2 inches also.
To loosen the nut, I suggest the following: scrape away the yellow paint, and get some solvent (Kroil) on the threads.
The location of this nut is critical for the operation of the 3 point hitch. Note its current location (count the threads showing) before you disturb it.
I just bought a 2 inch spanner wrench - with 1/4 inch pins - on eBay. Here's the link to the seller:
NIP JH WILLIAMS 2" SPANNER WRENCH# 426 USA | eBay
Good luck!
-Don
Thanks Don
2019 BIG TEX 20PH-20BK+5 HI-TENSILE DOVETAIL TRL (A64277)
2019 BIG TEX...
New/Unused Wolverine 84in Dozer Blade/Snow Pusher (A65583)
New/Unused...
2001 Ford F-550 Flatbed Truck, VIN # 1FDAF56F61ED50387 (A65563)
2001 Ford F-550...
1990 FRUEHAUF 53' DRY VAN TRAILER (A64280)
1990 FRUEHAUF 53'...
Dueling Tree (A65640)
2007 PETERBILT 386 (A65643)
2007 PETERBILT 386...
